Cap failure prevention?
  • vampares
    • Nov 2005
    I have a number of self built and used systems that I maintain, both software and hardware. All of these use intel processors and most use intel chipsets. I have never knowingly had a capacitor related problem before (although I have p3 HP w/ asus mb that locks under load in about 5 mins but otherwise runs fine , 45+ days uptime).
    I was wondering what, other than shoding manufacturing, causes a cap to fail or degrade. I assume that heat is a major factor. Would it be effective to disipate the heat with something like aluminum tape? I have seen circuit boards w/ hot glue on the top of the caps (psu's etc). Can a cap's life be prolonged by reinforcement, at ones own risk, of the lid (I assume that the white cross pattern across the top is for explosion prevention) or will the cap fail internally regardless of the cans condition? Do caps have lifespans or is failure more a function of circumstance and quality?
  • linuxguru
    • Apr 2005
    • 1564
    Re: Cap failure prevention?
    The vent pattern is a safety device, similar to a fuse, to prevent any build-up of gas that could cause an explosion. The problem is not in the can, but rather in the composition of the electrolyte and the electrodes. It's a materials quality issue, and very little can be done to delay it, except perhaps slightly improved cooling and air-flow.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Like lg said, usually the key issue is the electrolyte, with heat playing a role. The life of a good quality cap is a function of its operating hours, the magnitude and frequency of the ripple current, and the ambient temperature.
      WRT glue/RTV, this can decrease the cap's ability to dissipate heat; OTOH, the purpose of the glue/RTV is to improve the cap's stability under vibration and mechanical shock.
      PeteS in CA
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
        Securing a good thermal interface between...
        10-07-2024, 04:35 AM
      • jeybee
        surface pro 3 teardown. battery failure.
        by jeybee
        in the process of replacing the battery.
        managed to get the screen off without breaking it.
        used a solder station hot air set at 200 deg
        used a piece of aluminium from the bottom of the takeaway tray and a foot scraper blade that can be bought in most pound shops.
        starting with a cold device i heated up the screen slowly and evenly around the edges with the air gun. then concentrated on the area by the speaker, i inserted the foot scraper blade just under the glass, slicing the bonding glue and worked towards the closest edge, applying heat regular....
        10-02-2021, 11:44 AM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
