Upgrade system to Core 2 - Recommendations?
  • mockingbird
    replied
    Re: Upgrade system to Core 2 - Recommendations?
    No, I don't like ROHS compliance because they use lead-free solder. In any case, I don't think it will be a problem because the northbridges probably don't run hot enough for it to fracture.
  • Quasar
    replied
    "The ROHS compliance bothers me."
    Why?
    http://www.supermicro.com/products/m...3/C2SBA_II.cfm
    Q
  • PCBONEZ
    replied
    Originally posted by mockingbird
    The ROHS compliance bothers me. What I/O do you have on the back BTW?
    Try READING. It's REAL easy..
    It is obviously RoHS and all the ports are listed.
    Since it will never need worked on RoHS doesn't matter anyway unless you have a habit of licking PCBs.
    I wish manufacturers would still make boards with full blown PS/2 and com/LPT ports and no integrated audio.
    They do.
    They are called workstation boards.
    They usually retail in the $300-$400 range.
    I have a few if you got lots of cash.
    Or you could turn off the sound chip in the BIOS like everyone else that doesn't want the on-board does.
  • PCBONEZ
    replied
    Re: New Beastie Arrives!
    You're welcome, and congrats!
    Originally posted by Quasar
    Wow!! ALL Sanyo caps and SEPC's... I'll never have to touch this board.
    Exactly!
  • mockingbird
    replied
    The ROHS compliance bothers me. What I/O do you have on the back BTW? I wish manufacturers would still make boards with full blown PS/2 and com/LPT ports and no integrated audio.
  • Quasar
    replied
    The "new" beastie came today -
    SuperMicro Motherboard C2SBA+II 775 w/ Core 2 Duo E6850
    Wow!! ALL Sanyo caps and SEPC's on CPU VRM. I'll never have to touch this board.
    I have 2 gigs of Crucial PC2-5300 from another build.
    Now just waiting on the HSF (pic) I ordered.
    Thanks PCBONEZ for the heads up on the board combo!
    Q
  • PCBONEZ
    replied
    Sir, all I see are specifications for a DC-DC conversion module for the VRM 8.4 and 8.5 spec. Where have you proven that Intel did not ever in fact provide tualatin support on non-spec'd boards?
    Your lack of comprehension is indeed amazing.
    Intel does the spec'd-ing on their own boards.
    If Intel supports it then it's spec'd-ed.
  • mockingbird
    replied
    Originally posted by PCBONEZ
    I think it does.
    I'm not going to copy past it line by line for you.
  • PCBONEZ
    replied
    This still doesn't answer the fact that Intel claims support of Tualatin Celerons on a 815 A motherboard with a bios update.
    I think it does.
  • mockingbird
    replied
    Wifey want to do movie night tonight so here:
  • PCBONEZ
    replied
    Interesting. I did, in fact, use this processor when this motherboard was in my machine.
    Are you also saying that the Celeron Tualatins were VRM 8.4? If not, you will have to concede that Intel supported Tualatins. From the same Bios PDF:
    Two more things. There are two versions of the 1133 chip. The 256KB Cache and the PIII-S 512KB Cache which I assume the board would reject for not being a "server-class" board.
    Also, you state that the VRM spec was 8.4. Why did I need the lin-lin adapter then?
  • Quasar
    replied
    Thanks for the tip on eBay PCBONEZ. I put him in my fav. sellers, so I'll get emails occasionally.
    I went to that auction and saw that there was no BIN option. Seeing what these are going for separately, doesn't hold much promise of staying within budget and leaving any bucks for RAM.
    The search continues...
    Q
  • mockingbird
    replied
    The 1133 MHz version *happens* to have a core voltage compatible with VRM 8.4.
    That's why Intel approved it on the board...
    That's also why it was [unofficially] dubbed the "Coppermine-T".
  • PCBONEZ
    replied
    But they did. Here are the release notes for the BIOS' for that board: P21-0039.PDF. In there you see:
  • PCBONEZ
    replied
    I am so lost with all this back and forth. Are we talking at all about current boards, or is this all older, no longer available boards?
    Both
    Hashing the attributes of manufacturers.
    So, again, what/who manuf are available in todays market that would be a good choice for upgrading?
    Different opinions on that was reason for all the hashing and thrashing. Kinda natural for mobo-nutz.
    I'm good with the Asrock "multi-board" if that might only require a recap on delivery. I realize the 2gb RAM limit, but I have a system with 4 gigs in it that really is no better or worse than the 2 gig system.
    Problem is you might go through 2 or 3 before you get one that works right and if you are preemptively recapping you are voiding the warranties as you go.
    You might get lucky on the first one, but you might end up spending a lot more money [and time] than just getting a better board in the first place.
    If I understand correctly, even choosing a E4xxx or E5xxx would easily triple my current setup in speed, smoothness, yes?
    YES!
    If I chose the C2D CPU, do I have to change to the DDR2 RAM at that time, or is that also a "when I'm ready" possibility?
    Kind of RAM depends on the specific mobo.
    I also discovered, and no one said anything (odd) that there is a USB to Parallel cable to let me use the current printer with any board.
    I discovered the hard way that these simply don't work with a lot of HP printers.
    For some reason Windows and/or the HP drivers can't 'see' the printer through whatever chip they use in the adapter.
    Not sure if other brands of printers have the same problem.
    Are you looking for ATX or uATX?
    I personally would probably look on eBay for a used Supermicro C2SBxxx series or an i945Gxx chipset based board that has the features you want.
    They use polymer and Sanyo caps.
    [The C2S series has one 'bug' being they don't work with KVM's, but that doesn't matter to most people.]
    REALLY check the features closely. Some have the printer ports and some don't. Some have IDE ports and some don't.
    http://www.supermicro.com/products/m...oard/Core2Duo/
    http://shop.ebay.com/?_from=R40&_trk...cro+C2S*+-chip
    I check eBay once or twice a week for good deals on boards on my 'hunting list' and by being patient I've picked up several C2SBA+II for around $50.
    This one might be an awesome deal for you and I know the vendor is okay.
    It's full ATX [which I'm not sure works for you] and it comes with CPU+cooler and has the printer port you want.
    - Take a look.
    http://cgi.ebay.com/SuperMicro-Mothe...item564018f639
  • mockingbird
    replied
    Nope.
    VRM 8.4 has 4 VID lines and can't hit the proper voltage.
    VRM 8.5 has 5 VID lines and can.
    Lin Lin cheats with a voltage divider.
    No way Intel was going to approve a CPU for use on a mobo that can't do the right voltage.
    They are kind'a anal that way... LOL
    They were still selling boards overseas for years after that though.
    <snip>
    Wow! I had no idea. Foolish of them not to sell in the US if you ask me. They look like good products.
  • BigTroll
    replied
    you would not need to upgrade to ddr2 to use a core 2 duo on the asrock board.
  • Quasar
    replied
    If I understand correctly, even choosing a E4xxx or E5xxx would easily triple my current setup in speed, smoothness, yes? If I chose the C2D CPU, do I have to change to the DDR2 RAM at that time, or is that also a "when I'm ready" possibility?
    I also discovered, and no one said anything (odd) that there is a USB to Parallel cable to let me use the current printer with any board. Is this correct? Does it work, or are their tradeoffs? Going from 25 connections down to 4 it seems like something would be lost...?
    Thanks again for all the (overwhelming ) input!
    Q
  • PCBONEZ
    replied
    It's just a spec. The bus is still the same.
    Nope.
    The only thing Soyo I owned was the 6BA+ IV. Excellent motherboard, features wise.
    Soyo boards were decent designs but their use of crap caps made them go unstable after about a year.
    I was shocked to hear you write that they went bankrupt in '09, I thought much earlier, since I haven't seen motherboards from them in years.
    They quit selling motherboards -in the US- at socket 478 [I think].
    http://www.soyo.com.cn/topic.php?act...&productID=330
    http://www.soyo.com.cn/topic.php?act...&productID=331
    http://www.soyo.com.cn/topic.php?act...&productID=326
    http://www.soyo.com.cn/topic.php?act...&productID=327
    http://www.soyo.com.cn/topic.php?act...&productID=328
    I am however disgusted when certain disreputable vendors which I will not mention are advertised by hardware sites as legitimate, when it is also obvious that they too are shady. A certain power supply and video card vendor comes to mind. They tend not to honor their rebates and warranties after they go bust, but they always seem to reincarnate themselves under a different name, while cleverly disassociating themselves from their previous obligations. The gimmicky and gadget sample addict websites *cough*HardOCP*cough* are only too happy to prostitute themselves to advertise to the masses.
    I'm with ya on that one.
    Also love PSU reviews that only mention the brand of the big primary cap[s] and act like it's a big deal because its a big cap. - Or better yet, show a photo of the inside where you can't see the caps and they don't mention cap brands at all. - Of course they'll write like a paragraph about how pretty the box was...
  • mockingbird
    replied
    Tualatin requires at least VRM spec 8.5.
    D815EFV/D815EPFV have a spec 8.4 VRM.
    You can't change VRM chips with a BIOS flash.
    It's just a spec. The bus is still the same. The lin-lin adapters allow you to run Tualatins in non-tualatin motherboards. And like I said, INTEL THEMSELVES released microcode updates for this supposedly non-tualatin board. I can boot with one in and show you if you like.
    Soyo completed Chapter 7 bankruptcy in 2009.
    Hsing Tech bought the name but the company itself went *poof*.
    Hsing Tech = PcChips = ECS[now too]
    [I think we did that already...].
    Yea I remember these guys. There also used to be DTK, and a myriad of other fly-by-night vendors. Who cares? Were their products good? You can still go to China and get great off-brand motherboards and just recap them yourself and come off ahead price wise. The only thing Soyo I owned was the 6BA+ IV. Excellent motherboard, features wise. I was shocked to hear you write that they went bankrupt in '09, I thought much earlier, since I haven't seen motherboards from them in years.
