Apple Power Mac G4 Case
  • bigbeark
    • Jan 2010
    • 661
    Is it possible to use conventional (non-Apple) motherboards, ATX power supply etc in one of these cases?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Apple Power Mac G4 Case
    not without heavy modding
    if you want the look and a full size atx case, atech made a nice one. i have one. only beef is you have to dremel/saw the metal out of the metal part of the fan vent as it is horrificly restrictive to any airflow
    the nice part is geeks.com has them really cheap... i bought mine there
    theirs were originally fry's branded ones with 2 cd doors as opped to one (4 5.25 bays total either way). the dorky sticker they put on it can be removed to say fry's.
    they have them on sale for $14.99 plus shipping... sounds too good to be true but it is not... i have a thread around here (my case suggestions thread) on it.
    http://www.geeks.com/details.asp?inv...K6551G&cat=CAS
    the thread:
    https://www.badcaps.net/forum/showth...ght=atech+case
    now that i look, they
    sigpic
    (Insert witty quote here)
      • 31094
      i'll second that, it looks like it will work, but when you try the motherboard mounts & stuff dont align.
      the same goes for the G3 - i tried.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        if you drill and tap new holes, you can. in the article in my thread on the atech look alike case, tom's hardware mentioned people had done it. a PITA and if you f*ck up, you trash it. not for the fait of heart or the lacking in free time.
        sigpic
        • bigbeark
          • Jan 2010
          • 661
          This site gives detailed instructions on how to put a PC board in a G4 case:
          http://www.webfusion.net.nz/g4pc/
          I picked up the G4 Powermac case for $5, looks like an ATX power supply fits no problem.
          You are limited to Micro ATX or Flex-ATX boards.
          Looks like an interesting winter-time project
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            I did that in 45mins. I reppaced the power supply. Took like 5mins. Then i had myneighvor saw out the backplate area. Then i hotglued in a mini itx mobo. The hardest part was gluing a pc power button in there. I ended up using toothpicks
            Then i ripped out he innards agsin a month later and built a much more inreresting shoebox pc. I csn upload pix if u like
            And i no longer need the sawed out g4 case you can have it if you want if yure in san rafael
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
            • flusher
              Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
              by flusher
              Bought myself a project thing. Apple MBP16" A2141 820-01700
              No shorts, no visible waterdamage.
              Dead. no history.
              All USBC ports do 20V and charging battery.
              If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
              But what PMIC does is that it power cycles(dropping to...
              02-21-2025, 03:12 PM
              09-06-2024, 05:59 AM
