Type of Wireless-N (150 or 300) not specified in notebook advertising
  • japlytic
    • Oct 2005
    • 2086
    In a recene JB Hi-Fi catalog, all of the notebooks in it (excpept one which was not specified) had Wireless-N support (it would become standard issue considering that the 802.11N standard has been ratified), but they did not specify the type of Wireless-N (150 or 300), because not all Wireless-N clients and access points support 300 Mbit.
    From what I have read, all Intel wireless clients which support 802.11N supports 300 Mbit; so if an Intel wireless client is included in the notebook, it would support 300 Mbit.
    Do you think advertising of notebooks with internal Wireless-N clients should indicate the speed of the client (150 or 300)? I think so.
    Also, do you know of any internal Wireless-N (Mini-PCI or Mini-PCI Express) clients for notebooks which only support 150 Mbit?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Type of Wireless-N (150 or 300) not specified in notebook advertising
    i agree... i would go further and say they should put the BRAND of the wireless in there...
    sigpic
    (Insert witty quote here)
    • Hondaman
      Hardware firewall to block ad servers?
      by Hondaman
      I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
      The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
      02-05-2025, 05:04 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • japlytic
      Maximum speed should be marked on network ports
      by japlytic
      I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
      One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
      12-19-2024, 05:04 PM
    • MDSI
      ASUS TUF707ZR - BIOS password
      by MDSI
      I have an ASUS TUF707ZR laptop with a BIOS supervisor password.
      I’ve dumped the SPI flash (2 MB Winbond W25Q16JW).
      Someone experienced can help me remove the password ?
      Model: ASUS F17-TUF707ZR-HX007
      SN : N5NRCX069330213
      Flash chip: Winbond W25Q16JW (1.8 V, 16 Mbit)
      Thanks for any assistance ...
      10-20-2025, 06:45 AM
    • maximus-bullitt
      Request: Dell PowerEdge R340 iDRAC9 SPI dump (Winbond 25Q032)
      by maximus-bullitt
      I’m working on a Dell PowerEdge R340 (Service Tag: JTMLKB2).
      The iDRAC is bricked — system hangs at “iDRAC initializing,” fans at 100%, and no VGA output.
      The cause is a bad firmware flash to the iDRAC SPI.
      Board details:
      - Model: Dell PowerEdge R340 (14G)
      - iDRAC version: iDRAC9
      - Flash chip: Winbond 25Q032 (32 Mbit / 4 MB)
      - Tool used: CH341A programmer
      What I need:
      - A clean, working 4 MB `.bin` dump of the 25Q032 from another R340...
      09-28-2025, 04:22 PM
