SATA PCI Cards?
  • bigbeark
    • Jan 2010
    • 661
    SATA PCI Cards?
    I see there ar all kinds of PCI adapters that allow you to add SATA Harddrives to older motherboards not so equipped.
    Most seem to be Chinese made, obtainable from HK or mainland.
    Does anyone have any experiece with these? Are there SATA150 and SATA300types? Most seem to be based on a VIA chipset. Any good?
  • toastygoodness
    • Jul 2005
    • 813
    Re: SATA PCI Cards?
    yeah msot are based on via for normal pci. don't expect performance, just barebones. maybe an ide to sata would even be better.
    • Deft
      • Sep 2010
      • 55
      Re: SATA PCI Cards?
      @toastygoodness:
      I think you meant SATA to IDE
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: SATA PCI Cards?
        No point in SATA300
        The PCI bus can only provide 133MB/sec performance, SATA1 is 143MB/sec and SATA2 is 286MB/sec
        There are allot of such cards, some cheap crap and others decent by Promise, LSI and 3ware etc
        Depends on how much you wanna spend...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Re: SATA PCI Cards?
          I have one of the "cheap crap" cards, a Silicon Image Sil3112a in my dual-PIII. Actually this chip was used on the first sata mobos as well, so don't complain... It does 90MB/s easily. Not anything to write home about, but certainly beats the crap out of IDE.
          There's no point in spending hundreds of $$ for a Promise or anything.
          A working TV? How boring!
          • toastygoodness
            • Jul 2005
            • 813
            Re: SATA PCI Cards?
            Originally posted by Deft
            @toastygoodness:
            if you plug it in from the motherboard first, wouldn't it be ide to sata?
            • toastygoodness
              • Jul 2005
              • 813
              Re: SATA PCI Cards?
              i don't recall silicon image being considered "cheap crap"
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Re: SATA PCI Cards?
                Well i paid $30 for mine, about 3 years ago. Now it's closer to $15. Some people would call it cheap crap compared to the other names mentioned in this topic.
                • Deft
                  • Sep 2010
                  • 55
                  Re: SATA PCI Cards?
                  You're modifying the HD to go from Sata to IDE not the board :P
                    • 31043
                    Re: SATA PCI Cards?
                    stay away from "sil" series chips,
                    looking through the Linux kernal source a while back to see if a specific chip was supported, i saw all kinds of comments in the code about hardware bugs/issues on those chips!
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      Re: SATA PCI Cards?
                      I played around with a PCI sata card and hard drive on this dell 4550 a few months ago. Never got anything good to happen. This may be because I didin't know what I was doing. I never could get it to accept the sata drive as a boot device so I gave up on it. The card and drive came out of a junk PC so there could have been problems there too.
                      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
                      Mark Twain
                      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
                      John Paul Jones
                      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
                      Rod Serling
                      • brethin
                        • Dec 2008
                        • 1907
                        Re: SATA PCI Cards?
                        I never use a PCI card but a mini card for each drive.
                        I have used these several times in various setups. They are not all that fast but alot faster than USB so if you have old IDE interface drives you want to add to a SATA interface and vice versa (they make them to work both ways) for say Jbod storage they work fine.
                        A PCI card would most likely be slower than a adapter card for each drive but cheaper.
                        • toastygoodness
                          • Jul 2005
                          • 813
                          Re: SATA PCI Cards?
                          or you could be modifying the mobo to go from ide to sata....
                          the whole things circular reasoning lol. personally i use an sata cable instead of ide throughout the case because its more compact, but if you like to connect the adaptor at the back of the hard drive instead, be my guest.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Re: SATA PCI Cards?
                            They work just fine for me.
                              • 31043
                              Re: SATA PCI Cards?
                              hey junk, you couldnt get it to boot because the card had no bios - only a few 4port cards have a bootrom with them.
                              • severach
                                • Aug 2007
                                • 1055
                                Re: SATA PCI Cards?
                                I bought a Silicon Image and discovered that it was terrible so I bought VIA, Initio, and JMicron. JMicron was the only one that wasn't a total disaster. The rest have problems with hot plugging, hot plugging with the tray icon, boot and image incompatibility due to incorrect CHS values, failure to pass SMART data, failure to show up in the BIOS as a boot device, drive compatibility, and excessive error retry.
                                Now to find one that isn't super stingy on ports.
                                sig files are for morons
                                • bigbeark
                                  • Jan 2010
                                  • 661
                                  Re: SATA PCI Cards?
                                  I foolishly assumed that anyone making these cards would make them BOOTABLE. Seems like a no-brainer to me. But apparently the VIA cards are non-bootable. The target audience is apparently people that use them to flash the BIOS in the XBOX-360.
                                  So has anyone found any cards that are bootable?
                                  • bgavin
                                    • Jan 2007
                                    • 1355
                                    Re: SATA PCI Cards?
                                    VIA = Junk
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: SATA PCI Cards?
                                      Are you using Windows or Linux?
                                      Promise cards work in Windows.
                                      I intentionally never tried VIA or SI.
                                      For Linux I use 3Ware [which works in Windoze too] but those are all RAID cards.
                                      Mann-Made Global Warming.
                                      - Dr Seuss
                                      • Spacedye69
                                        • Nov 2005
                                        • 698
                                        • US
                                        Re: SATA PCI Cards?
                                        I have one of those as well and have had no problems. I think I payed $12 for mine a couple of years ago.
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                          Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                          by momaka
                                          Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                          11-28-2020, 11:08 PM
                                        • playit
                                          psu sata power wires thinner - does it make a difference ?
                                          by playit
                                          hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                                          i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                                          any explanation on this ?? thank you ,soon i am planning to buy some branded...
                                          10-12-2023, 05:25 AM
                                          HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                          This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-12-2024, 03:28 PM
