Compaq wassit?
  • kiddznet
    • Jul 2010
    • 176
    Compaq wassit?
    I have just been given this Compaq board
    Not a lot of writing on it
    It posts but I dont seem to be able to do much in the bios to get it to run an OS. It was in an office network
    I'd like to use it in a build can anyone point me to user manual bios etc?
    Pentium4 478 socket
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
    • 31029
    Re: Compaq wassit?
    you have to do better than that.
    i assume it's trying to net-boot.
    try removing the battery for a while.
    and most foto's that actually show some text or numbers on this thing.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Compaq wassit?
      its from an evo.
      nothing unusual to do vs any other board.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: Compaq wassit?
        yup. evo. the 2-pci extender is the giveaway. older than mine, mine uses a p4 ht northwood (fileserver)
        sigpic
        (Insert witty quote here)
        • kiddznet
          • Jul 2010
          • 176
          Re: Compaq wassit?
          Hmmm well I have googled til I'm blue and I can not find a pinout for this front panel connecter.
          Anybody help there?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Compaq wassit?
            http://www.google.com/search?hl=en&q...=&oq=&gs_rfai=
            Mann-Made Global Warming.
            - Dr Seuss
            • kiddznet
              • Jul 2010
              • 176
              Re: Compaq wassit?
              Like I said.....
              • mockingbird
                • Dec 2008
                • 5484
                Re: Compaq wassit?
                Experiment. Keep shorting two pins at a time and when it turns on you'll have the power pins. Plug in the HDD LED while it's on, etc...
                • kiddznet
                  • Jul 2010
                  • 176
                  Re: Compaq wassit?
                  Screwdriver did that... and away it went.I didnt really want to because I dont know what I might stuff up but hey....pins 2 and 3 from the top left are the PWR the rest will be easy with a little LED test rig
                  Now to see what I can do to get it to boot into WinDoze.. The bios is a very strange affair...
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Compaq wassit?
                    Originally posted by kiddznet
                    Like I said.....
                    Psst...
                    You have to actually look -IN- the manuals.
                    - Dr Seuss
                    • kiddznet
                      • Jul 2010
                      • 176
                      Re: Compaq wassit?
                      Not found in any manual but in a forum
                      Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
                      17 15 13 11 9 7 5 3 1
                      18 16 14 12 10 8 6 4 2
                      Pins 1 and 3 = HD LED
                      Pins 2 and 4 = POWER LED
                      Pins 6 and 8 = POWER SWITCH
                      Pin 14 has no pin
                      EVEREST says the board is a COMPAQ
                      I reckon its one of these Compaq 283983-001 Intel 845 Socket 478
                      And it does run with either a Celeron or a P4
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Compaq wassit?
                        it was the evo board befoe they had the ones for p4 ht (like i have).
                        sigpic
                        • kiddznet
                          • Jul 2010
                          • 176
                          Re: Compaq wassit?
                          Now I have decided to use it I get a error 512 message on boot no case fan connected press F1 to start Well it used to go away when i hooked up a fan but now there are NO VOLTS on the connector
                          Have I shorted something? there appears to be NO WAY to disable this in the bios.
                          • yyonline
                            • Jul 2009
                            • 692
                            Re: Compaq wassit?
                            That looks like an evo D510 board.
                            If I recall...and it's been a long while since I've seen one of those... It uses a voltage controlled fan. In other words, you might need a 5000rpm fan the bios steps down to half speed for normal use. Often times, the big box machines get really fussy if you change the CPU fan to something unexpected. Just a thought.
                            • kiddznet
                              • Jul 2010
                              • 176
                              Re: Compaq wassit?
                              Thanks. I had it running before using a 775 CPU fan. Now that doesnt work . Truly frustrating seems no way to bypass it in the bios either
                              512-Chassis fan not detected
                              grrrrr
                              • yyonline
                                • Jul 2009
                                • 692
                                Re: Compaq wassit?
                                I'd guess chassis fan would be some sort of case fan, not the CPU fan. If my memory is correct, the D510 has a 92mm rear fan. Make sure the fan you're hooking up has the 3-wire connector. Some boards use the rpm sensor wire to detect the presence of a fan, others use the resistance on the fan header.
                                • kiddznet
                                  • Jul 2010
                                  • 176
                                  Re: Compaq wassit?
                                  While I ponder that one I have a GA-8PE667 Pro dual bios thing in 478.
                                  Its starts but no post
                                  I have tried a AMIBOOT.ROM boot block with a floppy, shorted the two high number pins on the BIOS etc but NADA
                                  Frisbee time?
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Re: Compaq wassit?
                                    Beeps?
                                    - Dr Seuss
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      Re: Compaq wassit?
                                      No beeps. The floppy doesnt respond on start, have tried the Ctrl+Home/pageup but still nothing..
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Re: Compaq wassit?
                                        anything that could beep? if not then you never will hear beeps...
                                        sigpic
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
