mobo repair\advice
  • basscleff
    • Nov 2005
    mobo repair\advice
    Hi all, in the event your motherboard does die, and you cannot visibly verify that a cap has gone bad, are there any other tutorials here for troubleshooting motherboard/electronics repair?
    Specifically, VOM meter usage, ohm measurement, impedance, capacitance measurement etc. Maybe a quick how to for locating the root of the problem - when it's "visibly" seen?
    thx
    would appreciate some links etc.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: mobo repair\advice
    search for vrm testing and follow it.
    often no post is due to vrm death brought on by failed caps.
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Would VRMs apply to a working mobo that was "accidently o/c'd" and now won't do anything? No POST, no beep, no light. All other components, including processor, tested good. BTW, found this site while searching for repairs for other mobo with random reboot. WOW! A lot of bad caps and it still ran most of the time. Great site!
      p.s. "It's Great-n-Dayton"
      • Spacedye69
        • Nov 2005
        • 698
        • US
        p.p.s. Dead mobo is A7V333, Nichicon H* and OST caps look good. Are the toroid cores suppose to be black? Rest I've seen are white or green. Wire looks good.
        Mobo with bad caps, EP-8KTA3, all GSC.
        • linuxguru
          • Apr 2005
          • 1564
          Replace all the GSCs and the random reboot problem should disappear.
          On the dead motherboard, try recapping all the caps near the CPU/VRM, as well as any on Vsb. I haven't seen a bulged OST yet, but it's possible that they vent through the bottom seal and dry out quickly.
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Was just looking at it again, and one of the caps(Nichicon HM) is tilted. Do they tilt for any reason other that bad(assuming machines never assemble anything wrong!). Cap is in the middle of FETs and toroids. Thanks for the reply.
            • linuxguru
              • Apr 2005
              • 1564
              No, it can tilt during assembly or later, when the heatsink is installed, etc. But Nichicon HM(M)s have had issues, so recap that one anyway.
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Cerberuska
                Mobo MSI B550-A PRO password popup
                by Cerberuska
                Hello guys,
                I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                BIOS I updated to last one.
                any suggestions?
                And same thing for two different 5600G, and yes, MoBo supposed to support it.
                Thank you...
                11-10-2024, 01:23 PM
              • mrsith
                Dell G3 17 3779 - no display after mobo replacement
                by mrsith
                Hi guys,
                I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                04-30-2023, 05:11 AM
              • Ibod
                Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                by Ibod
                HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                Not sure where to go from here ?
                Is the PSU at fault or is the mobo causing the problem
                Look forward to any help :-)
                If I plug the 24...
                02-08-2023, 11:00 AM
              • Felipe_Serra_83
                Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                by Felipe_Serra_83
                Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                So I got this Dell Inspiron to play with.
                No charger, so I connected to my bench PSU.
                The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                ------What it did (and didn't do)------
                1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                2) Removed RAM, changed slot. Same...
                04-04-2024, 12:39 PM
