PowerMac G5: No cold start
  • pentium
    • Mar 2006
    • 2778
    Weird.
    So I power on my G5 tonight and....nothing.
    I get fans but it acts dead. I leave it on for a bit and then cycle power and then it comes to life.
    After multiple tests, it appears that my G5 will now only chime and start up if you first start it cold, let it run for a few minutes, then cycle the power. It reminds me of my old badcap-ridden AMD board where it would not POST until you power cycled it after a few seconds.
    It has no badcaps, the LCU has been repaired and the only problematic spot on the board where coolant was eating at it has been cleaned up.
    What could be causing this? I did get it briefly giving thre blinks "incompatible memory" but have not seen it since.
    Find Nedry!
    Check the Vending machines!!
  • Toasty
    • Jul 2007
    • 4171
    Re: PowerMac G5: No cold start
    >>It has no badcaps<<
    PSU caps are good too? I'd monitor the voltages to verify that it's all up and where it should be. Has it the LiteOn Tesla Converter PSU? p/n: 614-0307 ?
    veritas odium parit
    • toastygoodness
      • Jul 2005
      • 813
      did you reset the PRAM and stuff like that?
      • pentium
        • Mar 2006
        • 2778
        PRAM was reset.
        PSU in these towers are also of good quality. most die from drowning in a leaking LCU.
        Find Nedry!
        • severach
          • Aug 2007
          • 1055
          ESR goes down as the temperature goes up. Sounds like caps to me. What's the status of the board?
          You've recapped it before and by now maybe one of the replacement caps is starting to go bad. As fast as a G5 eats perfectly good Rubycon MCZ I wouldn't expect anything to last long cooking in that oven.
          You've not recapped it because all the caps look good and are a good brand.
          You've recapped the bad ones and no more look bad. I've partly recapped one G5 twice. By the second time it was clear as the cap death moved in an orderly fashion from one side to the other that caps in G5 are only a matter of time. When one goes they are all close. A partial recap will always result in endless rework. All or nothing for the G5.
          sig files are for morons
            • 31144
            weak point of well designed psu's is the startup cap.
            usually 2.2-47uf at around 35-50v
            • pentium
              • Mar 2006
              • 2778
              This isn't an imac G5, it's the PowerMac G5.
              They don't have cap issues. The main thing they die from is a leaking LCU or detached memory controller (in which case, the system is REALLY brain dead).
              Find Nedry!
              • seanc
                • Nov 2008
                • 1319
                I'm sure I've seen someone repairing a PowerMac G5 PSU around here somewhere...
                Here's one: https://www.badcaps.net/forum/showth...ghlight=liteon
                Possibly this: https://www.badcaps.net/forum/showth...ghlight=liteon
                Keyword.. Liteon.
                Hence Toasty's earlier question.
                • Toasty
                  • Jul 2007
                  • 4171
                  Well, I've 3 dead PowerMac power supplies that say different. Plus one on the way in...
                  veritas odium parit
                  • AudioCraZ
                    • Sep 2009
                    • 147
                    I have repaired many powermac with bad power supplies. I would always check that first.
                      • 31144
                      any psu can lose the startup cap, it's small and dont last well.
                      • toastygoodness
                        • Jul 2005
                        • 813
                        yeah i agree with the startup cap if you've done all that good stuff.
                        • pentium
                          • Mar 2006
                          • 2778
                          >_>
                          <_<
                          >_<
                          Fine!
                          I'll take it into work tomorrow and throw it against a pile of PSUs we got and see what happens.
                          Find Nedry!
                          • Toasty
                            • Jul 2007
                            • 4171
                            Well, the one that was on the way arrived. Not at all like your problem though. Total death. Took out a switcher, fusible resistor, fuse, and some small transistors. And the Ltec & Taicon caps all check ok.
                            Again, which PSU is it? PLEASE
                            Can you at least monitor the PSU voltages when it does this and see? Maybe one is not coming all the way up, or is "bouncing". It is odd to have the fans run and not have the PSU come on.
                            There are also a few "sense" lines that feedback to the PSU from the mobo. A 5v and a 3.3v. The 12V lines (12V1, 12V2, 12V3) are all sourced from the same bus, they just go to different connectors. So 12V on P3 is the same 12V on P2.
                            5VSTBY is Pin 1 on P1.
                            25V is Pin 8 on P2
                            On/Off is Pin 14 on P1
                            TACHO is Pin 3 on P1 (fan speed monitor)
                            I'm sure you've checked, but there was some chat about a video card problem and or re-seating it.
                            Good Hunting!
                            Toast
                            veritas odium parit
                            • pentium
                              • Mar 2006
                              • 2778
                              I know the Quad G5 PSUs are a different design. I know a fair number of them like to blow up.
                              I forgot to pull mine out to check. It's a real bitch to remove. >_>
                              Find Nedry!
                              • seanc
                                • Nov 2008
                                • 1319
                                I know a guy who had a brand new Quad G5 in storage for backup purposes.
                                The day came where it was needed, plugged it in - BANG!
                                  • 31144
                                  caps probably leaked or depolarised in storage.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    *BUMP* Was this ever resolved Pentium?
                                    veritas odium parit
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      I got assed into tearing my box apart because I dropped a screw which slipped under the PSU.
                                      Wow, the PSU was actually the fault.
                                      Find Nedry!
                                      • seanc
                                        • Nov 2008
                                        • 1319
                                        Pictures?
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • nono34
                                          Hisense stuck in Colors cycle like test pattern.
                                          by nono34
                                          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                          10-24-2024, 04:31 PM
                                        • Yoda79
                                          Samsung ue55nu7021k Boot cycle
                                          by Yoda79
                                          Hi, wondering if anyone can help with a tv which seems to turn on but turn off soon after and continue to do this cycle over and over again.
                                          It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the back and can see the backlights turning on. However when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
                                          Any thoughts, any help would be greatly appreciated.​...
                                          06-30-2024, 03:43 PM
                                        • willoriker
                                          motherboard power cycle MAX VI Gene
                                          by willoriker
                                          hi to everybody
                                          i have a asus maximus VI gene with a power cycle, i made a lot of diagnostic, but i could found the problem
                                          i check power sequence, all power source ( 5. 3.3 1.5 1.05, 3.3 cpu vmr) every is ok
                                          without accesories ( no proc no ram nothing) mother start and keep working
                                          when i insert cpu, mother boot up, post secuence start .. for 4 second post card show tipical info, and the power cycle begin.
                                          some behavior . start post and restart. i test, replace bios with difernte version..... NOthing
                                          try difernt powe supply, porcessor, anbd memories....
                                          05-16-2023, 03:34 AM
