imac g5 dvd hell
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: imac g5 dvd hell
    good point!
    it booted the 10.4 cd from the external like a charm. nice. and fast.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i thinks i hve the solution
      don't be a cheapskate and buy the dvd-rw dl's
      bought some, burnt my .iso i convered, popped into the external and bam! installing as i type.
      if this works, i will attemt to boot using the internal (nice it worked for topcat)... if not, then i found my extra dvd burner (old sony from 2003)... into the enclosure it shall go...
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        it worked... posting from it now...
        sigpic
        • seanc
          • Nov 2008
          • 1319
          #64
          Glad you managed to get there in the end.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            crap. the new drive for the enclosure will not do dl. i guess i will need to order another dl i guess (my existing one is for a usb burner that i do not want to gut).
            edit- found a firmware update which did the trick.
            sigpic
            • ryogadan78
              iMac A1418 - No LED, no power after overvoltage on Ethernet port
              by ryogadan78
              Hi guys, I need your help again.
              I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
              When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
              06-10-2025, 03:49 AM
            • Stephen
              iMac M1 DFU restore issue
              by Stephen
              iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
              this is the message it gives me with the error
              Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
              Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
              03-07-2025, 12:19 PM
            • Stephen
              iMac 27” 2020 Boot issue
              by Stephen
              Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
              08-16-2024, 09:32 AM
            • tommy97
              iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
              by tommy97
              we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
              Any ideas what might've...
              04-20-2024, 04:48 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
