Unknown System Failure
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Unknown System Failure
    Oh, be patient and wait for a cheap one.
    Not 100% sure, but I don't think the improvement will be -that- huge.
    Not 100% sure because I kind'a skipped that one.
    I went from 2.4Ghz/512k like you have straight to the 1M cache Prescotts without any steps in between.
    I did check the 'P4 drawer' just in case, but no joy on a 3.06/512k HT.
    Mann-Made Global Warming.
    - Dr Seuss
    • Sparkey55
      • Jan 2010
      • 1523
      Originally posted by PCBONEZ
      And don't buy one from an idiot like this that puts a CPU pins-down on a carpet to take a pic of it.
      http://cgi.ebay.com/Intel-P4-3-06GHz...item19bef6f1a5
      Do Not Buy from that seller. I bought some pc parts and a pc case from him about 2 years ago. He did not pack them well, the case was busted in shipping ( used just a handfull of styrofoam peanuts and a old soap box) loose parts inside case broke. IDIOT!
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Yes Sir PC I'll do as you say. I have to..LOL After I get done doing this brake job on the wifes car I'll be more broke than broke anyway. Got to do it. The front rotors are about .200 under and the worst pad is about .064 thick or less. I'll be doing it today if those "brand new" rotors are still on that junked car at the boneyard.
        "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
        Mark Twain
        "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
        John Paul Jones
        There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
        Rod Serling
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Two coming up that may go cheap.
          http://cgi.ebay.com/Intel-P4-Process...item33609e3d46
          http://cgi.ebay.com/Intel-Pentium-4-...item1c1552effb
          And they do go cheap sometimes:
          http://cgi.ebay.com/One-Intel-P4-3-0...item33604d7800
          - Dr Seuss
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Well the system lasted a few days only to end up with a wrecked windows install on the wd 80gig. I updated my mouse as well as my adware scanner back to back. Both updates failed for some reason. On the next boot none of the screen icons and programs were associated with anything. I'm sure this sick install could be fixed but I don't know how. After reconnecting the Maxtor 30gig with Xp on it the PC has been running fine. I'll reprogram the 80gig tomorrow and be done with it. Screw ups like this should happen at the beginning of reprograming not at the end. Dang it!
            Mark Twain
            John Paul Jones
            Rod Serling
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Well I reprogramed it yesterday. It booted this morning and did a BSD with a mini memory dump. Rebooted and it is working fine again. Something is up but I don't know what. Guess I'll run the WD hard drive diags and memtest 86 and see what I can find.
              Mark Twain
              John Paul Jones
              Rod Serling
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #47
                i test first with smartudm on the last xp 22 disk first.iirc i sent you one last time we did some swapping.its on the hirens boot cd.
                the lines to pay the most attention to are reallocated sectors and current pending.
                on the last screen reallocated will be displayed.
                a few are tolerable unless there are a bunch in current pending.hundreds or thousands means you own a paperweight!
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  I'll have to find that and run it. I did run the WD diags and Memtest86 and came up clean.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • seanc
                    • Nov 2008
                    • 1319
                    #49
                    How many passes did you run memtest86+ for?
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      I did two passes with memtest86 as a quick test. I will let it sit here and cook on memtest86 later tonight for a few hours. As for a replacement hard drive if needed I did find my newest ATA133 40gig WD drive stashed in my cabinet. I have a programed Maxtor already in the Dell case but that drive slows the system down. I don't even think its ATA100. The thing just may be ATA66. I don't remember owning or buying any Maxtors in years so it must be something I stock piled when parting out some old PC.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        I have a friggin virus on this thing again! Will be reprograming soon because of it. I think that this virus came from C-Net when I downloaded ether Adobe or Java. I have these programs on disk too so I'll use them for the install this time. I'm also going to switch out the ATA133 80 gig for my ATA133 40 gig. I just don't need 80 gigs of space.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • seanc
                          • Nov 2008
                          • 1319
                          #52
                          You'll get viruses through your older versions of Flash and Java because they're not up to date and have security holes in them which *are* being exploited. You MUST keep Flash and Java up to date.
                          Why did you go to CNet for Flash and Java? Get it straight from the source, you know the installation packages won't have been interfered, with and Adobe and Oracle don't run nasty banner ads on their websites which contain exploits for the above.
                          Also, try and stay away from IE, Firefox is a little safer.
                          • Sus256
                            HISENSE 65E7KQ PRO - no boot
                            by Sus256
                            Hi all!
                            HISENSE 65E7KQ PRO
                            RSAG7.820.13512 - chassis
                            MT9618BAATAB - cpu
                            RSAG7.820.12059 - power
                            HD650Y3U77 - panel
                            KLM8G1GETF - emmc
                            The TV does not turn on, the standby indicator is on. All voltages are present.
                            Emms is dead. Not readable, not detected.
                            Replaced emmc.
                            But with another dump there is no launch
                            Terminal log
                            UART
                            AC_ON
                            RPMB key is not yet programmed
                            HASH1_VERSION=0x00000000 64bit
                            E-B
                            FDE enabled
                            layout pattern onebin by SAR7,0...
                            06-01-2025, 02:11 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • Stachujones
                            Dell XPS 13 9370 unknown USB devices in device manager
                            by Stachujones
                            Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
                            Device manager says "unknown device, failed to request device descriptor"
                            Can somebody point me in right direction what to check?
                            I updated bios to the newest version and thunderbolt controller firmware still no luck
                            04-05-2025, 07:35 AM
                          • ctroxtell
                            Carrier HK50AA063 display controller common failure help
                            by ctroxtell
                            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                            02-05-2025, 05:31 PM
                          • howardc64
                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                            by howardc64
                            Problem
                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                            Model & Board Pics
                            Conflicting Spec
                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                            https://www.shopjimmy.com/vizio-gj-2k1...
                            10-10-2024, 01:16 PM
