Are we losing confidence in Nichicon capacitors?
  • japlytic
    • Oct 2005
    • 2086
    We have all heard about the Dell GX270 boards with bulging Nichicon capacitors.
    Next, there is a Medion system with bulging Nichicon capacitors.
    Nichicon has been in the industry since 1950.
    Are we losing confidence in Nichicon low-ESR electrolytics?
  • Chris1992
    • Apr 2005
    • 561
    Re: Are we losing confidence in Nichicon capacitors?
    This issue was due to one of two factors, both affecting the HM, HN series. A certain shift at Nichicon's Hong Kong plant was found to be over-filling the caps with electrolyte, thus causing their early failure. In an unrelated incident, some SARS disinfectants were found to harm the caps. I personally would use Nichicon, but have found a better price on ChemiCon KZE.
    The great capacitor showdown!
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      The company I work for - not in the computer biz - uses Nichicon a lot, though not the HM or HN series (we use 35V and higher, and those series don't go that high). In my testing, I see PR, PJ, PW, LXV, and LXZ as peers. FC doesn't fare as well, and PM (PL) does even worse. My testing is well beyond the parts' ratings, though. HE, KZE, and ZL have endured very well, and I see them as peers; YXG and FM haven't done as well as ZL, et al, but still much better than PW, et al. HE (and similar), KZE (and similar), FM, and most Rubycons use a different electrolyte technology than do PR, PJ, PW, FC, LXV, LXY, and LXZ, and are lower impedance (sometimes called "ultra-low impedance").
      PeteS in CA
      • custommadename
        • Oct 2005
        Hello. I don't think we're losing confidence in Nichicon capacitors. Nichicons can bulge as much as they want in Dells, and I'll still have confidence in their superiority in today's markets because they rarely fail else where.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I've only seen the HM and HN series nichi's fail. The PL and PM series are still very high on my ranks of good caps. Just avoid the HM and HN series caps.
          Rubycon is by far my favorite brand though.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • PeteS in CA
            • Aug 2005
            • 3581
            PM is basically lead-free PL.
            PeteS in CA
            • MrCreosote
              • Dec 2005
              • 31
              I like to use the HE's because of the high life.
              What is interesting is that higher life values occur if you can use higher than 10v or larger than 10mm diameter.
              (and Digikey stocks them)
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • DrewPhillips
                Capacitor Diarrhea - Nichicon PL Series
                by DrewPhillips
                Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                03-02-2025, 10:18 PM
              • xnRS
                Exactly same capacitors from NCC and Nichicon
                by xnRS
                I was searching some caps and found NCC KY and Nichicon UHE. I was looking for 1000uf 10v 8 x 20 mm. If you'll look into data, you'll see that impedance at 20 and 10 degress celsious is same, same applies for the ripple current. Also, I saw same thing with some other big caps(680uf 400v, or something like that, don't remember exactly) and saw same thing from NCC and Nichicon, no other manufacturer. This leads me to one idea - they are using same factory and just rebranding some caps.
                Any opinions on this one ?
                10-15-2021, 03:23 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
              • Hitto
                Fake Nichicon capacitors with almost-perfect sleeve?
                by Hitto
                Fake Nichicon capacitors with an almost-perfect sleeve?
                Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                It truly looks like the real thing.
                I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                Shall we be afraid, at this point, that even the bung can be replicated?...
                01-09-2021, 03:07 PM
