Reliability of measuring ESR in circuit
  • cnfcomps
    • May 2010
    I am trying to repair a socket AM2 ASUS motherboard which will not complete POST (no video, no beeps). I am using the Atlas ESR meter. A row of capacitors near the processor socket all registered high ESR (around 1.84). Now I have de-soldered them, they all register low ESR (around 0.02).
    Is it possible for something else on the board to be causing the high ESR value?
    Would the high ESR value in circuit indicate other problems with the board, or could it be normal?
    Many thanks for any advice anyone can give.
    Matt.
  • delaware74b
    • Apr 2009
    • 628
    Re: Reliability of measuring ESR in circuit
    You were probably reading more than 1 cap while in circuit and thats why it's recommended to test out of the board. This rule holds true for most components, not just caps.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • Rado108
      Measuring ESR in-circuit: LCR or ESR meter
      by Rado108
      Hello. Which tool is better for in-circuit testing of e-caps? I was thinking about getting proper LCR meter like DER DE5000 but as i have seen more accurate are ESR meters like ESR70 from Peak if we are measuring in-circuit. Is that true?
      Sometimes ESR can not be accurate when in-circuit but still want to get the best tool for it.
      09-10-2023, 10:42 AM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • rddube
      Lenovo L490 Ram voltage circuit malfunction
      by rddube
      Hello friends,
      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
      07-15-2025, 04:41 PM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • прямо
      Viper22A 5VSB circuit
      by прямо
      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
      01-13-2024, 07:05 PM
