I have a motherboard That had a lot of Rubycon caps on it . But it also has a lot of cap's that just have a large A on them. Some of these are black and some are the same color as the Rubycon's. All of them do have white writing on them. Any one have any idea who makes these?
Unknown cap maker
Re: Unknown cap maker
Pictures/Photos?I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
by sam_sam_samI got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to... -
by StachujonesHello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
Device manager says "unknown device, failed to request device descriptor"
Can somebody point me in right direction what to check?
I updated bios to the newest version and thunderbolt controller firmware still no luck1 Photo -
by apostsamkingHello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by Grucha98Hi i have problem with laptop. In bios I have idle and ac adapter unknown but on PS_ID_R i have 2v33. What voltage should be on PS_ID_R?
Dell 5300 NorthBay 18827-1
Thx for help... - Loading...
