Question about capacitor size with same rating
  • Nier
    • Aug 2020
    • 5
    If the capacitor rating is identical but if the replacement capacitor is smaller in size, does it matter?
  • PeteS in CA
    • Aug 2005
    • 3580
    • USA, Unsure of Planet
    Re: Question about capacitor size with same rating
    If by "rating" you mean capacitance and voltage, it often does matter, because the temperature, impedance, and ripple current rating often matter a lot.
    On the other hand, if you are comparing a 30 year old capacitor and a 2021 manufactured capacitor of the same capacitance, voltage, temperature, impedance, and ripple current ratings, the newer part might be smaller, due to technology progress.
    PeteS in CA
    • Nier
      • Aug 2020
      • 5
      I'm looking to replace Rubycon 2700uf 6.3v MFZ series and 1500uf 16v MCZ series on an old xbox 360. I couldn't find a datasheet for either rubycon series. Which capacitor brand and series is appropriate for a game console? Would a capacitor labeled for general purpose and with low impendence work?
      • AleXis6
        • Feb 2021
        • 69
        • Belarus
        just some information here
        https://www.badcaps.net/forum/showthread.php?t=26134
        https://www.badcaps.net/forum/showthread.php?t=18911
        https://www.badcaps.net/forum/showthread.php?t=53198
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Per Hansson
          Motor run capacitor physical size vs voltage rating & measurements?
          by Per Hansson
          (TL;DR skip the first paragraph)
          I encountered my first dead motor run capacitor at a customer this week.
          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
          (Unless a servo motor makes more sense that is).
          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
          The pump would run but sometimes trip the 10A breaker.
          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
          Then it could...
          09-20-2020, 06:32 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Adenitz
          Explanation of capacitor rating
          by Adenitz
          I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
          The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
          What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
          12-26-2022, 12:36 AM
