Bad Caps in the Movies !!!!!!
  • MrCreosote
    • Dec 2005
    • 31
    Has anyone ever spotted any?
    Around 1:26 in My Mom's New Boyfriend there is a closeup of a board with a 2x3 layout of 6 caps where 4 are clearly swollen and probably all 6.
    I'm just wondering if I might be the first person on the planet to see bad caps in the movies. Probably not, it's almost impossible to be the first at anything after the internet.
    Anyhow, I was quite excited to notice them - it would be hard not to, the closeup is very!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Bad Caps in the Movies !!!!!!
    oh I thought you mean the website. I found it on Prime, free. Got a screenshot, what you guys think this circuit really is (was)? Doesn't look like a prop
    • RJARRRPCGP
      • Jul 2004
      • 6304
      And, I thought that was exciting in a strange way, when I saw bad caps for real at a PC recycling place in Windsor, Vermont, probably back in 2008 and 2009!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        Might be a MSI BX Master? That LED + cap arrangement kinda looks like one.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
          master hoarder
          • May 2008
          • 12175
          It definitely looks Pentium II / Pentium 3 era with that golden-green PCB and "CET" TO-262 MOSFETs.
          It probably is just a prop - most likely they got a bunch of old hardware from a recycling center somewhere or their own old computer inventory (on that note, I suppose it's interesting to think how movie studios find their props, where to they keep the stuff, and how do they decide what to keep long term and what not to.)
          BTW, I also thought the tittle of this thread suggested that badcaps.net forums was featured somewhere in a movie. Now that would be fun to see.
          (And free advertising for TC?)
          • MrCreosote
            • Dec 2005
            • 31
            Those of you who researched the device, did you watch the movie and notice them like me? or just ran with my tip?
            Wow, I would say over 50% of XP computers that I've had had them. (I was doing a neural net project and had many running at the same time training.) Power supplies too.
            I even contacted Jackon I believe and scolded them for their bad caps and that it would be a nice goodwill gesture to send me replacements. So they sent me bags of 25-50 for 3 or 4 sizes that I encountered bad. All for free. I have to compliment them.
            • lti
              • May 2011
              • 2557
              Jackcon was sending people replacement caps many years ago. I don't think they were much better.
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
