Help! Need to replace capacitor on expensive motherboard.
  • pwnship
    • Apr 2021
    • 3
    I recently found a broken/missing capacitor on my EVGA Z390 motherboard. After contacting EVGA they were not able to provide repair/warranty service or information on the part I need to do the repair myself. Can anyone identify this capacitor and where I can buy a replacement? The cap has the following markings:
    FP
    88CG
    5 6 1
    6.3
    • 31036
    Re: Help! Need to replace capacitor on expensive motherboard.
    560uf 6.3v polymer
    you need to check the diameter yourself - probably 8mm
    and check the pitch between the pins - probably 2.5mm
    • pwnship
      • Apr 2021
      • 3
      Just measured:
      6mm diameter
      2.5mm distance between pins
      Any idea where I can find/purchase a replacement?
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        wow, I've never seen a poly break off
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          look in the FAQ subforum under the thread Where can I buy replacement capacitors?
          make sure u buy the right size as the original! watch the diameter, height and lead spacing as well as lead thickness or width! or else it wont fit on the board!! look for nichicon fpcap 560uF 6.3v. that the same brand and series as what the original is. tho u can get panasonic oscon sepc or chemicon npcap polymers as well.
          i have. usually they are too close to the edge of the pcb and in an inconvenient spot. so then pulling the video card or mobo to remove it caused the cap to break off.
          • Dthklr008
            • Apr 2021
            I need help with finding a replacement for a cap on my mobo as well the markings read : 5KY37 C with a dot in the middle (reminds me of the halo emblem) 270 16v it is part of the vrm's on an Asus m5a78l-m plus/usb3 rev 1.01 am3+ board (yes I know old but still does good) I had to move the cap to allow space to put heatsinks on the mosfets of the vrm (needed just a mm more space) so instead of bending or pushing I decided to desolder reposition and resolder however I am not happy with the end result of the connections so I would like to get a cap to replace the old one with longer leads to give me a good connection from my googlefu I believe the cap is a 270uf 16volt cap roughly 8mm diam and 12.5 mm tall but would really like to be sure before I actually damage anything beyond my ability to repair thank you for your time and sorry for so much text
              • 31036
              yes, 270uf - your right.
              depending on your standoff/case height you may be able to fit the cap on the other side of the board!
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                I have as well, and the cap was close to a PCB edge where installing another PWA or a tool slip could hit the part hard enough to partially break it off. I've also seen cases of MLCCs being so close to a PCB edge that the process of breaking apart panel-ized small PCBs flexed and cracked the MLCCs (small PCBs are not fabbed and stuffed individually; a batch of the PCBs are fabbed onto a large panel, components installed and soldered, with holes drilled to enable breaking apart the individual PCBs).
                I hope that wasn't as clear as mud.
                PeteS in CA
                • brethin
                  • Dec 2008
                  • 1907
                  Fat Fingered bullies kill electronics!
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    nay! fat headed dumb unergonomic designers kill electronics!
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      Both, though component density is starting to preclude good ergonomic design.
                      IOW: (Component Density) + (Designer Density) + (User Density)
                      PeteS in CA
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        all end user/purchaser fault for wanting smaller and smaller devices!
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Not necessarily.
                          Manufacturers also want to make smaller stuff too, because smaller usually means less materials used... which usually translates to lower production cost and higher profit.
                          • brethin
                            • Dec 2008
                            • 1907
                            Wrong , smaller isnt cheaper, smaller cost more .
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              No, it depends on the device.
                              If you want to make a PSU a small as possible with the current technology... yes, it can get expensive due to having to use really high quality rugged parts that can deal with the heat and provide high efficiency (as otherwise it may not be possible to make the PSU in such a small size.)
                              But on the other hand, if you put a regular PSU in a really huge space that isn't really needed, then you are wasting materials that could have been saved for use on producing more units.
                              So in essence, both extremes cost more money.
                              That said, if you look at the trend of technology in the last few decades, you will see that things have gotten smaller not just because the user only wants it, but also because it saves materials and is **usually** cheaper to manufacture.
                              • chth96
                                Is it no harm to replace with capacitor without ripple current rating?
                                by chth96
                                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                Rubycon YK DataSheet (b...
                                04-19-2024, 05:19 AM
                              • chth96
                                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                by chth96
                                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                I know that these capacitor will not last as long as nichicon capacitor...
                                12-22-2023, 04:34 AM
                              • chth96
                                Should I replace polymer capacitor?
                                by chth96
                                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                Is this ESR value of polymer capacitor correct?...
                                11-18-2022, 04:22 AM
                              • Mini1
                                Fujitsu U757 - help with identifying what STM32F103 is doing. Can i replace 7th gen motherboard with 8th gen?
                                by Mini1
                                Hey. I have a Fujitsu U757 motherboard with number CP732277. And i want to replace it with U758 motherboard like with CP755900 or whatever U758 series motherboard. U747/U757(7th gen CPU) all motherboards look exactly same so i'm sure it won't matter which one to use. But i would like to upgrade a bit and get U748/U758(8th gen CPU) motherboard. Motherboards all look exactly same layout as U747/U757, but i found one chip is soldered on U747/U757 which U748/U758 doesn't have. It is STM32F103 MCU which is near screen connector. And i'm not sure will U748/U758 motherboard will work with my U757 laptop....
                                01-28-2024, 05:01 PM
                              • cap__
                                Can I replace 15uf capacitor with 22uf?
                                by cap__
                                "If I wanted to replace an old 15uF/400V capacitor with a new one,
                                I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                                11-29-2023, 11:16 AM
