One or all?
  • The_YongGrand
    • Aug 2005
    • 5
    One or all?
    I'm planning to recap my MSI-5184 m/b. But, I have only a few of them I could buy and the rest of the caps I couldn't find yet in my place. So, I plan to replace only 3 out of 9 bad caps. The severe bad caps are near the DIP switches (ah, those little flip-switches - maybe something to do with Voltage core or whatsoever)...
    So is replacing 1/3 of bad caps removes 1/3 of all the problems? What if when I replace 1/3 then the problem is solved and ignore the rest? Please advise...
  • Chris1992
    • Apr 2005
    • 561
    Re: One or all?
    Bad idea not replacing all badcaps. Even if 1 badcap is left, you could still get the symptoms and finally motherboard failure.
    The great capacitor showdown!
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
    • black6host
      Replacement caps for Samson Resolv studio monitor 65A Amp board.
      by black6host
      Good day!
      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
      I'm going to replace the caps and I'll be the first...
      02-06-2024, 08:22 PM
