3300uf 6.3v for xbox
  • jayjr1105
    • 281
    Re: 3300uf 6.3v for xbox
    Seems like this brown cap all the way on the left corner is in parallel with the other two caps I replaced on the lower right side. Is that possible being they are so far away?
    https://prnt.sc/uabe84
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
      • 31214
      yes, the caps are often placed close to the chips that consume the most power.
      • jayjr1105
        • 281
        I mean, I have never seen it before where a cap is in parallel with caps far away on the board. Continuity with the positive lead determines that right?
        Ryzen 3600x
        FX-8802 Iron
          master hoarder
          • May 2008
          • 12175
          Correct.
          It's actually very common for the voltage rails from the power supply to run all across the board and have parallel caps everywhere where there is high-power consumption, as stj noted. Those brown caps in particular supply that you pointed out appear to supply the VRMs. So it's normal what you see.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Placing caps close to varying and pulsing loads decreases the trace resistance and inductance between the load and the energy stored in the capacitor. With ICs with very fast high magnitude load transients there often is a network of capacitors of different value and type, some that are very low ESR and ESL but low capacity to respond fast, some that are higher in capacity but also higher ESL to handle what the faster lower capacity caps could not handle. Sun Microsystems was doing this in the mid 1990s.
            PeteS in CA
            • jayjr1105
              • 281
              Great, thanks for those explanations. My final question is, should I replace that final 3300uf brown cap with a 2200uf to match the other two? Remember I replaced the bottom right one AND populated that empty cap spot with two 2200uf 10v Panasonic FM's. A third Panasonic 2200uf on the left side would complete the original 6600uf total capacitance.
              Ryzen 3600x
              FX-8802 Iron
                • 31214
                no, because your decreasing the cap value.
                if you replace a 3300uf cap, use a 3300uf cap or use a 2000uf polymer.
                if the circuit didnt need 3300uf them M$ wouldnt have paid for one.
                • bulkchart32
                  • Oct 2020
                  • 32
                  if you search the forum i'v done a number of posts about this subject and how to upgrade to polymer caps
                  did u notice any difference in performance when upgrading to polymer caps?
                  • jayjr1105
                    • 281
                    Caps either do their job or don't. You won't see any differences unless you hook it up to a scope maybe.
                    Ryzen 3600x
                    FX-8802 Iron
                      • 31214
                      well it doesnt crash - so the polymers work
                      • bulkchart32
                        • Oct 2020
                        • 32
                        so high quality caps won't reduce the amount of frame drops while playing a stressful game?
                          • 31214
                          framedrop is because the hardware is pushed to the limit.
                          • jayjr1105
                            • 281
                            If you don't go the polymer route, I've concluded that these are best cheap option for 1.0-1.4 xbox's.
                            https://www.digikey.com/en/products/...332MHD/2598225
                            And these for 1.6 models since they are closer together and you should go with 10mm wide caps
                            https://www.digikey.com/en/products/...C10X25/6049998
                            Yes 27mm height is acceptable on the right side of the board, just not under the optical drive.
                            Both caps are very low (not quite ultra low) ESR and have adequate ripple current.
                            Ryzen 3600x
                            FX-8802 Iron
                            • ecordovas
                              • Sep 2021
                              • Peru
                              #34
                              Hi, I was looking information about the following:
                              I have an xbox 1.0, that has 5x 1500uf caps and I am wondering if can I change those by 3 x 3300uf caps? Would it be safe for the console?
                                • 31214
                                yes, but using 5 polymers is better.
                                and the 3300uf caps are tall - so dont put one in the way of the heatsink clip
                                • ecordovas
                                  • Sep 2021
                                  • Peru
                                  #36
                                  Thank you for the quick answer @stj
                                  I don't have many options to buy replacement components, I can only work with things in Amazon, because I live outside US and I want to fix my xbox soon.
                                  Maybe I can order the polymer capacitors for the future, so I can replace them some months in the forward, should I use the same specs 1500uf 6.3v and 3300uf 6.3v (I have 1.0 - 1.6 xboxes)?
                                    • 31214
                                    find my thread about fitting polymers - it has lots of links to aliexpress.
                                    • EFritz20
                                      Xbox classic/original 10v 3300uf Polymer replacement?
                                      by EFritz20
                                      For polymodding an original Xbox i'm looking for polymer replacements of the following capacitor:
                                      2x 10v 3300uf Nichicon PW
                                      One is on the left side of the board, the other one on the right as you can see the picture i linked below (the two big brown caps).
                                      Could i just use 2200uf polymers to replace them or do i really need the capacitance?
                                      I have searched the forum already but could not find an answer for it.
                                      Thanks....
                                      03-25-2022, 04:47 AM
                                    • ohren
                                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                      by ohren
                                      Hello!
                                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                      Measured voltages with no load:
                                      After rectifier diodes
                                      12V: 6.17 V
                                      5V: 5.67 V
                                      Secondary transformer pins AC measurement (really don't know if this says anything)
                                      12V: 2-2.5 V
                                      5V: 1.04 V
                                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                      03-18-2023, 10:33 AM
                                    • tccyo22
                                      Xbox One Original missing 12v enable signal
                                      by tccyo22
                                      Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                                      Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                                      08-14-2023, 06:06 AM
                                    • TMTGTR
                                      An Xbox One PSU Odyssey
                                      by TMTGTR
                                      Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                      =>Background:
                                      I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                      06-17-2022, 05:40 PM
                                    • bulkchart32
                                      does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                                      by bulkchart32
                                      i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                                      05-16-2025, 07:33 PM
