Need new caps
  • Nagoshi
    • Nov 2009
    • 3
    Need new caps
    Nobody replied in my https://www.badcaps.net/forum/showthread.php?p=87951#post87951 but all I really want is what caps should I replace them with.
    The mobo is a DFI LANParty UT nF3 250Gb.
    List of caps:
    - 20 x Nichicon 1000uF 6.3v HM 105C
    - 5 x Chemi-con KZG 1000uF 10V
    - 1 x Chemi-con KZG 470uF 16V
    - 4 x Chemi-con KZG 1500uF 16V
    - 6 x Chemi-con KZG 3300uF 6.3V
    - 18 x Chemi-con KMG 100uF 16V
    - 4 x Chemi-con KMA 100uF 16V
    The two caps that went visibly bad are Nichicons.
    Thinking about re-capping the whole motherboard. What should I get?
    Thanks!
    DFI LanParty UT nF3 250GB [bad caps]
    ML-30 / Mobile 3000+ Claw CG / 3400+ Claw C0
    2x512MB Corsair XMS4404v1.1 TCCD
    6800GT
    Corsair 400CX
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • iMic
    Vintage AT Power Supplies - Selecting Capacitors
    by iMic
    Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
    The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
    02-19-2023, 06:45 PM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
