Replacement for MCZ 1800UF 6.3v
  • pflowers
    • Jan 2009
    • 36
    I need replacement caps for the Rubycon 1800uf 6.3v 8X20mm MCZ....I found some posts here that claim the ncc HN series are good replacements.....but...
    1) I can only find 10MM I need 7 of them mounted in series with about a .5 MM space between them....10's wont fit I'm afraid
    2) the ripple on the HN is 2280 the MCZ is 2350
    3) Digikey has an 800 limit on the HN....I only need 7
    any thoughts?
    Paul
  • sofTest
    • Aug 2008
    • 361
    Re: Replacement for MCZ 1800UF 6.3v
    With replacement, do you mean you want another brand? If not, check:
    http://stores.ebay.com/PC-MotherBoar...QQftidZ2QQtZkm
    I've bought from this vendor several times, and the caps have been as advertised.
    The owner of this site, also got them in stock:
    https://www.badcaps.net/pages.php?vid=22
    Be a mensch
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      if they are on vcore i use fujitsu re 820@2.5v or nippon chemi con psa 820@2.5v
      these are solid polymers and were often speced in the vrm design anyway.
      i steer away from nichicon hn/hm due to the huge bad "lot" that spanned several years.
      • pflowers
        • Jan 2009
        • 36
        well looking at this Pic I would say yes they are on the vcore.....but then again I'm not a board guru (yet), perhaps I could get verification from one of you fine people.
        the 7 rubycon caps have been removed....those that are still there were not vent caps and are 820 / 2.5v as best I can tell the series is OS but I'm not sure on that......should I be pulling those as well.....it looks like all 11 were run in series
        Paul
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          yes the polys will work fine there.
          i would pull the remaining 4 and replace with all the same to be safe.
          lytics were used strictly for cost cutting.didnt work out did it?
          and those are all in paralel.
          • gdement
            • Jan 2007
            • 690
            If the caps in question are all connected in parallel, then they're almost surely Vcore. That's always the biggest bank of parallel caps.
            Best way to be sure is to find a pinout for the CPU socket and test against that. For mPGA478 you can do that by sticking a thin piece of wire into the socket.
            • pflowers
              • Jan 2009
              • 36
              sweet thanks a ton Kc....caps ordered and on their way
              this place rocks
              Paul
              • pflowers
                • Jan 2009
                • 36
                Well once again you guys have come through.....not just a good recap but a polymod recap at that.....system is up and running like a champ.....
                on a side note.....I woldn't suggest increasing the through hole size on the PCB it made it almost impossible to solder in the new caps....but as this was a freebie system I took the gamble
                Thanks again KC
                Paul
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  its a non issue to me as by desoldering system gets the holes perfectly clean but if "toughing it" with primative means of clearing holes lean towards the fujitsu re.
                  the ncc psa have thick leads and require the holes to be fully cleaned.
                  • pflowers
                    • Jan 2009
                    • 36
                    I have a nice rework station that was awesome when desoldering the power supplies I just finished (about 120 total) but I think the tip is a little too big to work correctly on a mobo....it just wouldn't pull the solder off right.....and I may be wrong but the through holes on the mobo looked quite a bit smaller than those on the PCB for the Power supplies......but even with that said, the files I got from Pace with the rework station made easy work of clearing those holes right up.
                    • bmernz
                      • Jun 2009
                      • 3
                      I have a very similar board from an HP xw4100 with the same problem - bursting Rubycon 6.3v 1800uF MCZ 8x20mm caps - which I am having trouble finding replacements for. I tried requesting pricing through the badcaps website (5 days ago - I may be being impatient!) , but have as yet had no response.
                      Can you be more specific about the caps you used as replacements? Why they were better/different? - Hopefully this will help me and others track down a suitable substitute and perhaps a local supplier (New Zealand).
                      Thanks.
                      • yanz
                        • Nov 2004
                        • 910
                        i would worry about what causing the problem of that bursted rubycon.. a bad airflow? a 'near of death' PSU? a bad design of mobo? a too hot pentium4 proc ()? or something else.. also, are they chemicon KZG near those RAM slots?
                        anyway, what is the model/series of that motherboard? (so someone with the same problem can track it from google search)
                        days are so short when you actually do something..
                        • bmernz
                          • Jun 2009
                          • 3
                          I suspect it's temperature, poor mains supply, and probably also time.
                          The caps sit in the exit flow of the CPU heatsink...
                          It's been on all the time in an engieering workshop... for the past 4-5 years.
                          The motherboard is from an HP xw4100 workstation, it has DURAY rev1.03 screened on it, and a sticker with SP# 361633-001 and AS# 325675-003 on it.
                          • Toasty
                            • Jul 2007
                            • 4171
                            Originally posted by bmernz
                            ...I tried requesting pricing through the badcaps website (5 days ago - I may be being impatient!) , but have as yet had no response...
                            Read the main page. TC is moving -
                            Toast
                            veritas odium parit
                            • bmernz
                              • Jun 2009
                              • 3
                              Toast
                              Ah, right, thanks.
                              I hope the move goes well!
                              • reformatt
                                by reformatt
                                07-31-2025, 08:37 PM
                              • the_rem
                                Unknown transformer : how to find a good replacement part ?
                                by the_rem
                                Hello guys,
                                I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                04-23-2025, 01:48 AM
                              • ezenia
                                PS4 controller left stick potentiometer replacement issue
                                by ezenia
                                Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                09-30-2023, 02:19 PM
                              • boosti45
                                Macbook pro logic board replacement parts quesion
                                by boosti45
                                i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                08-21-2024, 05:23 AM
                              • r2digital
                                klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                by r2digital
                                I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                04-18-2024, 03:50 PM
