Panasonic NHG caps suitable for starter cap?
  • mikay786
    • Aug 2014
    • 765
    Jamicon 4.7uf 400v - exploded
    Have got a couple Panasonic NHG caps in same value, would they be suitable replacements? Starter cap, one at the bottom. Connector next to it is AC in.
    • Jul 2011
    • 6040
    Re: Panasonic NHG caps suitable for starter cap?
    I do not see any reason why you can not use them
    It might be better if you used 450 volt caps instead 400 volt
    If the diameter is the right size and if it is not to tall
    • mikay786
      • Aug 2014
      • 765
      Man these caps must be terrible, two of them have spilt their guts underneath and one exploded.
      Not Jamicon as stated above but Jackcon caps
      2 x Jackcon 4.7uf 400v that have leaked
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • JohnsonJ
        Allen&Heath XONE92 DJ mixer repair
        by JohnsonJ
        Hello everyone.
        I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
        The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
        12-12-2020, 11:19 AM
        EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
        by momaka
        I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
        So, here is the...
        06-06-2020, 04:39 PM
