Replacing Caps - Ripple Question
  • THRobinson
    • May 2017
    • 13
    Hey guys, I have a monitor I'm looking to repair (see other thread) and I think from all the research I got it sorted out, but before I click to order, I had a question about 'ripple'...
    If say I have a cap that's 820mA@100KHz and I want to replace it, all other specs like uf, voltage, physical size, etc is the same... but can't match 820mA exactly, is it better to get something higher? or lower?
    Also... sometimes I see them listed @100KHz or @10KHz.
    I know 1A - 1000mA
    But if something is listed at 10KHz, is it one of those things where if you change 10KHz to 100KHz, you move the decimal over in the amps?
    Like... 405mA@10KHz = 40.5mA@100KHz? something like that? or if what I have is rated @100KHz, just stick with specs listed @100KHz?
    • 31170
    Re: Replacing Caps - Ripple Question
    higher ripple is best, because it's refering to ripple handling capability.
    • THRobinson
      • May 2017
      • 13
      Thanks... so when matching/replacing old caps, if you can't find an exact match, you can always go higher on the Voltage rating and Ripple and be safe.
        • 31170
        aim for equal or higher voltage / capacitance / ripple and equal or lower esr
        • THRobinson
          • May 2017
          • 13
          Thanks!
          For ones where it's a coin toss, I've been going for the ones rated with the higher lifetime@temp rating. Also, filtered to only show Nichicon, Panasonic, Rubycon and United Chemi-Con... I think half of my cart are Nichicon and half Rubycon.
          Actually, may be picking up a 2nd Samsung 204B this weekend for $10, with the slow power up issue. Been so long since soldered anything, and was never really very good, a backup would be good. Plus if fixed for another $10 worth of parts, sell it. Lot's of people using the 20" 4:3 screens for Arcade machine builds (like me) but hard to find, and harder to find working.
          Prob is, gotta wait to see if rev0.0 or rev0.1 before ordering. Gettin' impatient... I want to try out my mad solder skillz... from 25yrs ago.
            • 31170
            arcade collector? join the club.
            • THRobinson
              • May 2017
              • 13
              Maybe... if it works.
              Building a cabinet, fine tuning the design before I start cutting wood. Still stuck between using my RaspPi, or going way over budget and building a basic PC that will work better and play more, but again, cost more as well.
              I definitely wanted a 4:3 monitor though, since pretty much everything between 1980-2000 was 4:3. Lots of 5:4 monitors, close but not what I was after. Outta no where a few Samsung 204B's showed up for sale, but all with the same issues.
              The one I have already is a rev0.1 and at least 3 of the caps are a bit bulged on top. But... $10-15CAD for a monitor and another $10CAD to fix (I'm doing the large 100uf450v as well) I figure worth the attempt at least.
              I wish I paid more attention as a kid though... my Dad knew all this stuff inside and out. I still have some of his equipment but no idea how to use it all.
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
              • SwedishDiesel
                Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                by SwedishDiesel
                Howdy folks,
                I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                10-30-2021, 12:47 AM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • em132
                Help: Looking for guru input on upgrading an S12II-based PSU
                by em132
                The supply in question is an unused/"NOS" Antec EA-500 "80-Plus" (not the "Bronze") with Seasonic's early "500W" S12II board. While I don't yet have this supply in hand, I fully expect it to be filled with OST RLS and RLX. I plan to replace these with FR/FS Panos (mostly).
                Of course, I also plan on replacing the big kahuna on the primary side. To that end, I'm currently holding a pageant to determine who'll wear the tiara. Here are the four finalists:
                The ravishing "Lady in Red" is the current crowd favorite, largely...
                03-08-2024, 09:24 AM
              • Antonynl
                What are typical ripple voltages on a laptop motherboard?
                by Antonynl
                I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                So I have two questions:
                1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                12-09-2022, 06:51 AM
