whats the capacitance of this cap please
  • shaunbt123
    • Nov 2012
    • 119
    Hi there can some one tell me from the following information what the capacitance rating should be on ths cap.
    it is marked as follows.
    fl 1.5khp
    333h s*j45.
    is it a 333pf rated at 1.5 kv,or am i completely wrong.also whats the best place for a replacement.
    thanks for the help.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: whats the capacitance of this cap please
    Yes , it is 33000 pf , or 33 Nanof , or 0,033 Microf. at 1.5 Kilovolt capability .
      fl 1.5khp
      333h s*j45.
      Do you have pictures of this cap and where it is used in the circuit? CERAMIC? POLY?
      http://www.component.directory/index...cts_id=1045852
      http://www.ebay.com/itm/like/3915663...&ul_noapp=true
      • shaunbt123
        • Nov 2012
        • 119
        thanks budm.
        yes ill post some pics of the cap for you as soon as i can.. i pulled it from a lg tv power supply board :the tv model number is 42pj550-zd.the capacitance seems to read ok (34nf),but cant test the esr as my peak atlas esr meter wont read caps that low.
        • shaunbt123
          • Nov 2012
          • 119
          Thanks jiroy for the information.
            ESR meter is not really made for using on those kind of cap. I would say the cap is OK.
            • shaunbt123
              • Nov 2012
              • 119
              heres a pic of that cap budm,one of the legs has broken off so will have to get a replacement now.
                • 31300
                you get loads of those type of caps in crt tv's & monitors.
                • shaunbt123
                  • Nov 2012
                  • 119
                  just need to find a compatible replacement now.
                  • shaunbt123
                    • Nov 2012
                    • 119
                    could i replace it with this.https://www.amazon.co.uk/MKS4-33N-Ca.../dp/B01AIMD0L0
                      • 31300
                      you like being robbed?
                      go look here:
                      http://uk.rs-online.com/web/
                      • shaunbt123
                        • Nov 2012
                        • 119
                        http://uk.rs-online.com/web/p/polypr...itors/8829212/.would these be suitable,as a replacement.
