ASUS motherboard problem
  • ajsurkhi
    • Aug 2016
    • India
    Hi
    I have one ASUS m2n68 plus motherboard, when i switch on power supply cpu fan spin for few second then stop. After pressing ps-on switch nothing happen.
    I visually check all caps, all look like ok. what anything else, is there any capacitor problem or bad chip like sio chip or anything else.
    please help.
    • 31214
    Re: ASUS motherboard problem
    did you try another psu?
    if you did then check the motherboard for shorted fet's near the cpu
      master hoarder
      • May 2008
      • 12175
      Remove the 12V 4-pin connector for CPU power. Does the PSU turn ON with the motherboard showing no video. If YES, you very likely have a shorted MOSFET on CPU VRM. If not, then there may be a shorted MOSFET elsewhere *OR* your PSU may be bad.
