How to Recondition (Reform) Electrolytic Capacitors and Why
This is a sticky topic.
Re: How to Recondition (Reform) Electrolytic Capacitors and Why
I think there should be rubber plug in that hole, its pressure sealing. If it is gone, the electrolyte has been in contact with air - it's done.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Code:I have lots of stuff that have been sitting unplugged for 3-5 years. Not one has ever failed on me. Even some really old stuff that I found and plugged in that haven't seen power for over 8-10 years worked fine. Again, there's a reason why electrolytic capacitors are called "self-healing" capacitors. Of course, if you do want the caps to last as long as possible, then reforming the capacitors (or plugging in the device and using it) is recommended.
But if you really wanted to be extra careful with it, you can just attach a 60-100 Watt incandescent light bulb in series with the line plug. This should slow down the startup voltages a tiny bit, giving the caps more time to reform to full voltage. It will also limit the current going through the amp, should something decide to go bad inside (i.e. output stage going out). After 5-10 minutes operation, you can just plug the amp straight into the wall.
And of course, if you really are paranoid, you can take off the capacitors and reform them manually... but I would say that's not necessary at all.Last edited by momaka; 10-12-2018, 09:46 PM.Comment
(TLDR version second paragraph below).
Have been debating weather to post this in the funny shit thread or electronic mistakes thread but I'll go with here as it's "sorta" ontopic anyway
I always wanted a capacitor discharger for work, I've used all sorts of ghetto solutions but something nicer like Mr Carlsons capacitor discharger would be ideal.
Of course we then come back to my lazyness, for example in post #42 I write that I've bought a second digital display for my capacitor reformer, well, it still sits in the parts drawer today
So that got me looking for another solution, and actually my Fluke 113 with it's input resistance of 3kΩ is pretty ideal, however I don't use that for work as it's a useless meter.
My actual work meter, a Fluke 28-II does not have dual input impedance modes.
So I found the Fluke SV225 LoZ adapter, it looks pretty ideal for my purposes, but of course it has PTC's just like a regular meter otherwise it would catch fire if you connect it to the grid indefinitely...
So I wanted to test if a LoZ meter can discharge a large capacitor but of course I then needed a large charged capacitor, on my bench was a used 420v 390uF that seemed good for a first test.
I charged it to 30VDC with my lab power supply, the Fluke 113 could discharge it quickly but of course at 30VDC it had very little stored energy...
So I figured I'd use a servo that was on my bench anyway to charge it to 325VDC, that should equal 20J of energy if my math is not off.
However even with the bench supply's low 30VDC there was a quite big spark, so I thought I'd limit the current using a series resistor to protect the capacitor and servo.
There happened to be a resistor infront of me on the bench so in it went.
I connected her up and BOOM!
WTF just happened? Looked at the servo and it was fine, looked at the capacitor and it was fine too, but charged to only 175VDC.
The resistor you ask? It had a hole blown in it's side
I looked at it's color bands: yellow, violet, black, gold
That's a 47Ω resistor, maybe some of you are seeing were this is going now, if not look at this formula:
325v x 325v / 47Ω = 2247w, through a 1/4w resistor, hmm, I wonder why it blew?
Annyway to make a long story short I charged it with a 470kΩ resistor instead, that was much less entertaining though
The Fluke 113 discharges that in seconds.
I also tested to discharge the servo with it, on it's own it took over 5 minutes to get to single digit voltages, with the Fluke 113? Only 12 seconds"The one who says it cannot be done should never interrupt the one who is doing it."Comment
I doubt you're lazy. You probably just have more important things to do or too many projects, and that's why you don't get to this. I'm like that too, sometimes (though at times I truly am lazy). That said, I did actually make a somewhat more stand-alone capacitor reformer rather than using my breadboard every time. But when I have only one or two old caps I need to reform, I still do the "quick/lazy" way - i.e. a few jumper cables on the floor connected to a resistor and a power adapter.
Indeed as you noted above, the energy stored in that cap was about 20 Joules. For those wondering, energy stored in a capacitor is
E = 0.5 x C x V^2
where E is energy in Joules, C is Farads and V is volts.
Now, we also know (or do we?) that the energy E is the amount of power P applied in a unit of time t... i.e.:
E = P x t
So 1 Joule = 1 Watt x 1 second
The 47-Ohm resistor above might have started dissipating 2247 Watts of power, but that was only in one instant. As the voltage in the capacitor fell, so did the power the resistor dissipated. But we don't care about that. All we care about is the average energy (heat) it has to get rid of.
With 20 Joules, you can say that the resistor dissipated 2247 Watts in 0.0089 seconds... or 224.7 Watts in 0.089 seconds... or 22.47 Watts in 0.89 seconds... or to get a more meaningful result, 20 Watts in 1 second. And if we keep going further...How about 1 Watt in 20 seconds - energy is still the same. Would a 1/4 Watt resistor burn @ 1 Watt of power in 20 seconds? Or how about 1/2 Watt @ 40 seconds? - I think YES, very likely.Here ElectroBoom explains it too (and it's a good video, BTW
https://www.youtube.com/watch?v=xjW-isgOijs&t=7m17sLast edited by momaka; 10-24-2018, 11:43 PM.Comment
Nice write up. You could also crack your power adapter open and add a potentiometer to the feedback circuit of the PWM so you could then adjust the duty cycle to get different output voltages.------------signature starts here------------
momaka, read again, the cap was discharged, I was charging it up through the resistor. (So I could perform my tests).
Otherwise it was right"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Ah, I see.
Well, either way, it doesn't matter whether you try to discharge a cap that has 20 J of energy stored in it or whether you're tying to charge it to that potentially hold that much energy when it's empty.
And I do know how to mod these adapters, which is the funny part.
Hmmm. You've given me an excellent idea for a bench power supply now!Last edited by momaka; 10-25-2018, 06:06 PM.Comment
I had to open one to fix it once and was surprised to see it was just a mini SMPS. Since then, I've modified several, including one from a Nintendo DS which now provides 3.3 volts to a bluetooth module in my Logitech computer speakers. I have a few 3A@
12v ones from old cable boxes which I use when I'm fixing main boards, and you have actually given me the idea to use them
for a bench power supply as well. Not sure if I can get one all the way down to 1.25v, but it's worth a try. Just getting down to 5v would be fine for most of what I do. Maybe the laptop ones could be adjusted up to 24v, but your output current would decrease (I=P/V).------------signature starts here------------
Code:But if you really wanted to be extra careful with it, you can just attach a 60-100 Watt incandescent light bulb in series with the line plug.
Any bulb above 50 Watts should do really, but I generally recommend above 60W. The higher the power rating of bulb, the more current that can be drawn by the device (both at start-up and continuously). 60W will probably allow you to run the amp with a small load. 100 Watts bulb should allow you to crank it up a bit more. Not much of a difference otherwise. I've even used 40 Watt bulbs in a pinch, too - works with devices that have a lower idle power draw.Comment
Momaka, am I correct in understanding that the light bulb places some additional resistance on the device so as to charge caps more slowly and thus limiting them blowing out? It that is the case then the 100 W bulb will give the greatest protection?Comment
Lower Wattage = slower turn on and greater protection
Higher Wattage = faster turn on, less protection, but allows device to use more power.
With that said, you can't go as low as you like. Some devices will simply not work when the input voltage drops too much (i.e. when using a lower Wattage light bulb). So that's why I suggest 60-100W, as that will work on most amplifiers without trouble. I myself often get lazy and use my 40W soldering iron (it's a simple plug-in iron with a heating element, so it's pretty much the same as using a 40W incandescent light bulb). But I've encountered switch-mode PSUs that won't run with that.Last edited by momaka; 11-02-2018, 10:55 PM.Comment
Further to this discussion, it appears that for anything with electrolytic caps that haven't been used in some years would benefit from first powering on with 60 watt bulb. How about tube devices? Would they also benefit from this?Comment
The series incandescent bulb trick is well-known among restoration techs as an alternative to a variac (and in some cases, even better than a variac, since the bulb limits current too).Comment
Would anyone here be able to say:
1. What is the function if the diode in the original post?
2.Not only that, but a leaky cap (as in, capacitor with a high leakage current… not one that is physically leaking electrolyte) will usually trick your ESR meter to show lower ESR than what the capacitor may have. So if the cap has gone high ESR, your meter may not show it and you might end up putting a faulty cap back in service. To avoid this, check the capacitance of the cap. If it is higher than 20% of its specified capacitance, it is likely leaky and it is time to reform it. If you don't have an ESR or capacitance meter (like me), then definitely reform it so there won't be any doubts.
Since I use mostly SMPS PSUs for my projects, using a diode like that is OK, because the SMPS will simply just power-cycle until I fix the polarity mistake (that is, if the power supply is not too powerful - otherwise the diode would short out permanently.).
Reconditioning, however, will _NOT_ restore the original capacitance of the NOS caps. Nor will it restore bad ESR. Reconditioning is simply to "play it safe" before you insert NOS caps in a circuit. And if you ever buy caps and decide to store them, reforming them once in a while (once every 1-2 years.) may help slow down the deterioration rate.Last edited by momaka; 12-09-2019, 06:47 PM.Comment
i can see that it's far from ideal (but, perhaps, more practical) to reform the caps collectively in circuit; so how about, in respect to PC motherboards, removing the CPU and then connecting a resistor (which would be, for example, 10Kohm X n, where n= number of VRM input caps) in series with the VRM input caps and applying 16V to it, and after that (after changing the resistor value, and voltage divider, accordingly), to the VRM output caps?
Again, far from ideal, but better than firing up a board that hasn't being used for several years with no reforming
Would applying 16V to the high side, and then 6.3V to the low side, damage the FETS?Last edited by socketa; 12-16-2019, 04:10 PM.Comment
by AdenitzHello,
can I use this cap:
https://www.tme.eu/en/details/ues1h4...tors/nichicon/
Capacitor: electrolytic; bipolar; THT; 47uF; 50V
to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
What exactly I can expect to install bipolar electrolytic cap instead a regular one?
Thanks.-
by ten-dHi all!
I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...3 Photos-
by Perry BabinI have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
If not organic polymer, what would be the caps that could take the most abuse?-
Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
Aluminium Electrolytic
G = Series
10 uF
16 = Volt
104 Date code 2001 April? (not really important, but interesting)
Please help to confirm or correct if i am wrong. Thank you
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
- Loading...
