Replacing polymer cap with standard electrolytic
  • Bungz
    • May 2013
    • 133
    Hey guys
    Off the back of recapping a Asus A8V Deluxe and bringing it back to perfect health I have another board to fix.
    This board is a little more modern and the problem is a little more obvious, a cap has been broken off.
    Board works but has random restarts, hopefully the cap will sort this.
    The cap is a Aluminium Polymer and it is from what I can deduce 561uf @ 6.3v rating.
    Same as above (can see where it was removed from), if anyone can shed any light on its type or other useful details that would be cool.
    Problem is I cant find any of these local, I would have to order them especially which gets a bit ££.
    Would I run into any issues using a low ESR electrolytic of the same value?
    Sorry if this is a basic no no but id like to test the board to see if the new cap sorts it.
    Thanks in advance!
    PS the board is a Asus Maximus Gene V.
    • 30995
    Re: Replacing polymer cap with standard electrolytic
    if you use an electrolytic then even doubling the Uf would still be inferior.
    farnell sells polymer caps.
    • Bungz
      • May 2013
      • 133
      £20 minimum order for standard card payments which is a lot for one cap
      Hmm what to do
        • 30995
        you could find a local repair shop and ask if they have any trashed mobo's with poly's on them.
        rapid sells the same polymers btw.
        not sure about the delivery policy there.
        • mariushm
          • May 2011
          • 3799
          Use Farnell's UK "retail" site, CPC : http://cpc.farnell.com/ - should be free shipping, or minimal postage (under 5 euro)
          Or use TME.EU http://tme.eu (should be at most 5 euro to ship) or RS Components http://uk.rs-online.com/web/ (same shipping costs or less)
          All of the above have genuine quality components and they're good distributors, used all of them.
          The capacitor in question is a functional polymer capacitor, so it has very low esr. There are some electrolytic capacitor series that get close to polymer capacitors and the circuit the capacitor is in may tolerate higher esr well, but it's still a wiser idea to just use polymer capacitors.
          The capacitor is 560 uF 6.3v - some manufacturers use for some series the short notation for capacitance, first two digits times 10 to the power of the 3rd digit .. so 56 x 10^1 = 56x10 = 560uF
          To get even close to the polymer capacitor's specs you'd probably have to replace it with a 16v rated capacitor, and probably 1200-1500uF (but again IF the circuit tolerates so much higher capacitance)
          • Bungz
            • May 2013
            • 133
            I see guys, thanks for explaining the reasoning having checked the specs other than the uf and voltage I can see why I am best sticking to a poly.
            The problem is it is a very small size cap, 6 x 8mm with a 2.5 leg width and I cant see those in stock anywhere on the sites that you have listed mariushm, but I will go through and check again later.
            Thanks again.
            • bestsystem
              • May 2011
              • 59
              Or can you parallel a ceramic or polyester cap with a electrolytic to get around the polycap?
              • montemcguire
                • Mar 2015
                • 15
                Are you sure that this cap has broken off? From the photo, it appears that the two pads have never seen solder, and that the color of the pads is similar to the unsoldered portion of some SMD pads at the lower left of the picture.
                • Bungz
                  • May 2013
                  • 133
                  Yes there was a pair of legs there from the ripped off cap, I desolderd them cleanly.
                  Since then I have harvested a poly cap off a junk board and the Maximus is working perfectly.
                  • clearchris
                    • Dec 2013
                    • 687
                    Thank you, that solved a mystery for me.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • Noodneek
                      Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                      by Noodneek
                      My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                      I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                      08-30-2024, 12:52 PM
                    • MacGyver's paperclip
                      what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
                      by MacGyver's paperclip
                      TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
                      07-01-2023, 12:12 PM
                      Lenovo Miix 520 Business Editon Hybrid (2-in-1) 500 Specification for Upgrade or Repair
                      This specification for the Lenovo Miix 520 Business Editon Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 520 Business Editon boardview and 520 Business Editon schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 07:25 AM
