Supermicro S2DGE motherboard bulging capacitors
  • DrPogi
    • Nov 2026
    • 5
    Hi, newbie here with newbie questions.
    I just acquired a Supermicro S2DGE motherboard, dual slot 2. I think it's a fairly rare board. The seller indicated the caps look OK but sold it as-is. Sure enough I see some bulging caps. I have not attempted to power the board on yet, I do not know if it is functional.
    First, confirming, are these actually bad caps?
    Is it safe to install and power it on?
    If the caps are bad, recommendations for someone who could replace them? In order of preference, located in Sacramento region, SF bay area region, or shippable in USA.
    I have no soldering or electronics skills (C programmer). I'm otherwise fairly handy and not afraid of a challenge, should I dare learning on this board? At a glance it doesn't seem too difficult if I can find the right replacements.
    Thanks!
    Edit to add, the board otherwise looks pristine, not even dusty.
  • williamsc
    • Sep 2017
    • brazil
    Yes, the capacitors are bad. Ideally, you should replace even the ones that look fine, as their values ​may have shifted as well. If you have practical experience with replacing components, it would be a good idea to swap them out!
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3294
      • Singapore
      u can try looking in scrap heaps, asking a friend if they have a dead board for u or at the e-waste recyclers for free confirmed non-working motherboards to practice your soldering skillz with. its a hand skill where practice makes perfect so more stuff to practise on wont hurt. consider it a dry run so u dont muck up the actual board because its so rare, ancient and irreplaceable these days.
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • EmperorSunLao
        Help Identifying Replacement Capacitors
        by EmperorSunLao
        Hello everyone, nice to meet you. I'm new to this forum, but I'm a long time tech enthusiast with a sizable collection of hardware that mostly ranges from 1990-present. Sadly, that includes more than a few components that were created between 2000 and 2010, which seems to have been a rather dark time for capacitors. I have some motherboards with failed capacitors that I would like to replace, but determining proper replacements is proving difficult and I was hoping someone here might be able to give me a hand.
        I'm not entirely new at this, as I have desoldered and replaced electrolytic...
        10-07-2026, 10:12 AM
      • mario_split123
        PCChips/Hsin Tech M537 V3.1 Old motherboard capacitors
        by mario_split123
        Hello everyone !
        I am new to this forum and also a begginer/hobbyist in electronics. I have a question about an old AT motherboard model PCChips/Hsin Tech M537 V3.1. It hasnt been powered on for 30 or so years.
        I have read that it is not safe to power it on after such a long time because capacitors can suddenly burst. When I inspect capacitors I cant notice any visible damage,leak,corrosion or bulged capacitors.
        What are your suggestions ? Replace all capacitors maybe or ?
        Thank you in advance for your answers !
        02-17-2026, 07:18 AM
      • SuperSullivan
        ASUS A8V Motherboard Bulging Cap Replacement
        by SuperSullivan
        Hi there,
        This is my first question on this forum, so my apologies if this is formatted incorrectly or if there was a better section to post this.
        I recently acquired a desktop tower with an ASUS A8V motherboard, which is from around 2005 I believe. Unfortunately, there is a bulging capacitor just above the CD-ROM cable connector. From what I can see, this is a 6.3V 820uF cap. I'm not sure of the branding, as I can't see that well around the sides of the cap without taking the whole motherboard out.
        I do have an ESR meter, so I plan to move some stuff off my workbench...
        08-18-2026, 01:37 PM
      • stanwebber
        did bad capacitors kill my motherboard or prolonged exposure to faulty psu?
        by stanwebber
        i've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
        03-10-2022, 12:35 AM
