Hello everyone, nice to meet you. I'm new to this forum, but I'm a long time tech enthusiast with a sizable collection of hardware that mostly ranges from 1990-present. Sadly, that includes more than a few components that were created between 2000 and 2010, which seems to have been a rather dark time for capacitors. I have some motherboards with failed capacitors that I would like to replace, but determining proper replacements is proving difficult and I was hoping someone here might be able to give me a hand.
I'm not entirely new at this, as I have desoldered and replaced electrolytic capacitors before, but I am very much an amateur. When I did this before, I made the replacement based solely on matching the rated voltage and capacitance on the old cap to a new one. I've heard that ripple and impedance are also variables that need to be taken into consideration, but I didn't know that at the time and just got lucky it all worked out. Instead of relying on dumb luck, however, I'd really like to learn better how to pick replacement caps.
Here is what I'm looking to replace at the moment:
Motherboard 1
I don't know how this thing powered on when I received it, had to make sure it wasn't DOA, but it powered up to BIOS. Not only is it super dirty but I think I counted 26 failed capacitors across it.
The obviously failed capacitors here are labelled Teapo, which are in two sizes. Both have 01/06 on the side, which I assume is the manufacturing date. They also both say SEK 105C. The smaller ones are labelled 16V 100uF, while the larger ones are 6.3V 1000uF. I can't find much info on these, but I don't have much confidence in the brand at this point.
Motherboard 2
All of this board's capacitors actually look good, except this one that was nearly torn off in shipping. Markings read KZE 6.3V 1000uF.
Data Sheet
Possible replacement?
This is the best I've found so far looking for a replacement to this one. The voltage and capacitance match, but the impedance and ripple look fairly far off to me.
Motherboard 3
This board has just one capacitor that appears failed. Markings = OST 6.3V 1000uF RLS 105C O747
I included a picture of the failed capacitor (by itself) and two nearby capacitors that don't appear to be failed but have the same markings that were easier to read.
I found a page that suggested these as a possible replacement, but I haven't been able to find a data sheet to check more info on the original OST caps to be sure.
Motherboard 4
This motherboard has three caps in very bad shape near the VRMs. I haven't been able to find any info on these. Markings = KZG 16V 1800uF (M)105C 6(7) DG
Thanks for the help in advance
Motherboard 1
Motherboard 2
Data Sheet
Motherboard 3
Motherboard 4
