50+50uF bad cap?
  • Brianthewalrus
    • Sep 2026
    • 5
    • Ireland
    50+50uF bad cap?
    Hi all, new to the forum here. I am trying to repair an old philips portable record player from the 1960s. There is no sound getting to the speaker at all but it seems to be working ok otherwise.
    I have a question about this cap. It’s an AC 5307 50+50 300v. I can’t find a direct replacement.
    Will a marshall type 500v be ok to use in a pinch?
    The seal in the bottom appears to be gone so I think this is a no brainer to replace on this alone?
    The ground pin/casing to either of the poles reads 47uF, 0.95/1.7 ohm esr. Vloss is 8.6%.
    Appreciate any help.
    thanks
    brian
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8887
    It’s 3 terminal? So it has a common ground. You can use two 47uf caps for example. You got plenty of wiggle room. You could try to find a dual capacitor with a common ground, or you also could put two single caps and wire that to common ground.
    Minimum requirement is:
    A: the voltage rating must be at least the same or higher.
    B: the capacitance value must also be the same or a bit highter.
    Sure you can put a dual 50+50uf 500VDC cap in there, just thinking there are cheaper alternatives.
    High voltage caps have always higher ESR than their lower voltage ones even with the same capacitance rating.
    The only way to correctly measure a high voltage capacitor is with a big LCR that can do also a leak down test.
    I would change the cap anyway after all it is like 60 years old. You also can gut the old cap and stuff modern capacitors inside to still give the original look. Have fun!
    • Brianthewalrus
      • Sep 2026
      • 5
      • Ireland
      Thank you, some good solutions there!
      There are only 2 proper terminals, the third is the shell essentially. Looking up some esr table i can see the esr looks somewhat normal for that voltage. Maybe in the low side? I only have a basic component tester and multimeter so maybe not picking up the right stuff as you suggest.
      Ye it’s a bit of fun. Checking through the whole thing I’ve only found 2 resistors that are 50% high.
      They use an uninsulated wire to run the signal to the pre-amp. I think that could be shorting against another wire going into the pre-amp valve. Its all a bit alien. Im scratching my head at the bare wire! Not sure if its meant to be shorting into its neigbour or has that just happened over time!
      edit- now i ripped into it it seems it a grounded outer sheild. I think it way have made it way through the insulation. Hopefully thats the no sound issue sorted!!
      • playit
        450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
        by playit
        hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
        09-02-2023, 02:43 AM
      • paparazzo79
        wire from CPU cooler mount touches screw on the back of the sound card
        by paparazzo79
        Hi guys.
        When I removed all RAM modules yesterday, previously I had to remove CPU cooler and this thingy (dunno its name, this wire which hold fan onto the heatsink).
        Now when I want to reinstall sound card, as you see this wire touches one screw on the soundcard (marked with red).
        Could it short the soundcard or I am overthinking again?
        This is expensive sound card and would not want to damage it.
        Should I normally instal the soundcard into X1 slot without worries?
        One thing came to my mind is to perhaps isolate the...
        07-05-2026, 02:25 AM
      • wnlewis
        New wire for my RDE3340 Whirlpool electric range
        by wnlewis
        OK. I got the rocker switch figured out thanks to the good advice on this forum.
        Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
        This is a Whirlpool RDE3340 electric range.
        The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
        Where may I find parts...
        01-08-2025, 11:21 PM
      • lcdcaps1
        Quecoo T12-958 soldering iron tip not grounded
        by lcdcaps1
        Hi
        I have a Quecoo T12-958 soldering iron and have noticed the soldering iron tip is not grounded
        i dont want to use it like this
        I only found out because the chassis ground wire from the ground lug / bannana socket came off
        how can I ground the soldering iron tip
        What I thought of doing is soldering a wire from the ground leg on the soldering iron tip connector to the ground lug
        Would this be ok
        There is a earth wire from the PSU to control board but its not connected to anything.
        12-16-2025, 06:02 PM
      • emeskay
        Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
        by emeskay
        We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
        08-06-2024, 07:13 AM
