Component Combination
This topic has been answered.
  • DrDos
    • Aug 2025
    • 126
    • U.S.
    I have a Technics SA-404 reciever. Inside right next to the rectifier it has 2 EXRFS2032ZS Ceramic component combination capacitors. I think they are there to stop the hum and other osilations, anyway nobody has them that I can find unless I just don't know how to tell digikey what I want. So, I understand they are really to capcitors sharing a ground. Can anyone tell me what 2 capcitors make up these things. The parts list only shows 0.01uF (X2). Now I'm not sure if that means there are 2 for the reciever or it consists of 2 0.01Uf caps. I am hoping somebody can help me out with this because I really need to change them out. Thank in advance. I'll upload the service manual since I may have missed something there also.
  • Answer selected by DrDos at 08-24-2026, 10:26 PM.
    R_J
    • Jun 2012
    • 9775
    • Making Money
    Why do you want to replace them? I would bet they are ok and would outlast us both. they are just .01µf 250v disc caps across the bridge rectifier diodes, if they are not shorted, they will be fine
    Your picture shows a bad (C629, red) electrolytic, replace them before looking at ceramic disc's
    These are the same sprague P00914
    • DrDos
      • Aug 2025
      • 126
      • U.S.
      I found this talking about component Combinations. I'm not sure if it apply's to my situation but I thought I would post the info anyway. BTW do we have a place to post service manuals. I have one for Pioneer SA-5500 II and this technics SA-404 I could post.
      Common Configuration Strategies
      • Parallel Connection: Connects multiple capacitors to increase total capacitance and reduce overall ESR/ESL. This is often done by combining different values (e.g., 0.1µF and 0.01µF) to cover a broader frequency range for decoupling.
      • Series Connection: Used to increase voltage rating or achieve precise fractional values, though it reduces total capacitance.
      • Decoupling Best Practice: Use a 0.1µF capacitor for mid-frequency decoupling and a 0.01µF (or smaller) capacitor for very high-frequency noise suppression on critical ICs.
      • DrDos
        • Aug 2025
        • 126
        • U.S.
        This is what they look like and I still can't find them anywhere.
        • R_J
          • Jun 2012
          • 9775
          • Making Money
          • DrDos
            • Aug 2025
            • 126
            • U.S.
            Hmmm, you may be right. It looks like the top has expanded a bit. Thank you. Anyway They are not bad but there was a puff of smoke coming from the rectifier area and I just want to change everything over there. I'm going to use
            (2) 0.01uF 630V Radial Polyester Film Capacitors and piggy back the center pins. I know 630v is overkill but film caps will be a sort of upgrade. How can you tell the caps were 250v? Anyway, 2 of the primaries from the transformer
            hook up to these so I thought the 630v would be better. I haven't had the unit on long enough to test rails and such yet. It was blowing the filament in my dim bulb tester. Now I put a variac on it and it's working much better. The only incandesent
            I have is a 3-way 50, 100, 150 so the variac helps control the volts to the dim bulb. Thank very much for your help.
            • R_J
              • Jun 2012
              • 9775
              • Making Money
              Anyway, 2 of the primaries from the transformer hook up to these
              Are you sure about this? The primary connects to the ac line, NOT to the bridge rectifier.
              other schematics show the voltage and value of these caps. they are standard values used in this position.
              R627 (22Ω) is damaged and C629 is bulged, maybe that's where the smoke came from.
              • DrDos
                • Aug 2025
                • 126
                • U.S.
                Yes, I'm going to have to. I'm just learning about all this stuff and filling my brain rapidly. C629 has been changed and R627 was fine it just needed to be straightened out. Those Ceramic caps may be standard but I tried ordering some and digikey
                had none unless I wanted some square looking things. They seem to be out of these regular standard ceramic caps. Mouser didn't have any either or at least the ones I wanted to change.560pF 500v and 100pf 500v. All they had were Mica caps and I'm not paying $7 plus shipping for 1 or 2 caps. I pretty much have to back together now. I kept the original ceramic caps that were near the STK1050's with the exception of C622 which is a 0.01Uf 50v all I had was a 0.01uF 630v so I threw that in there. I have a lot of ceramic caps but my problem is only one batch had the volts printed on them and my TC-1 tester won't tell me the voltage nor will my multimeter. Well I saw the smoke from somewhere near the rectifier and R622. I did just clean with 91% acolhol so it may have been that. I'm waiting on a transistor now once that is in I'm leaving the L602 coil out and STK1050's and do a power on. For the power on I have a variac hooked up to a dim bulb tester and then the init which is about a safe as I can think of being. I'll see what happens at that point. I did find in my tacing that R907 (470 Ohms)was bad so I'm going to replace that also before I power up. I have a full schematic and parts list. Thank you very much for your help.
                • andrewsawesomr
                  • Jun 2022
                  • 117
                  • United States of America
                  • Coding, Electronics, Music
                  The "square-looking" ones are normal, the renderings just look weird on DigiKey. They have plenty 0.01uF 50V 560pF 1kv. If you look at the datasheets, you can see the real photos of the capacitors.
                  • DrDos
                    • Aug 2025
                    • 126
                    • U.S.
                    Wow! Thanks. I'm just learning about all this stuff so I can try and fix my own gear. I have bought from them several times and I thought how can I tell if that big square will fit where I need it? Anyway it's good to know that because I was getting about the same thing from Mouser, Jameco, and Newark. I actually gave up and went to ebay. Thanks again.
                    • Jodeanss
                      Infinity sub amp and Onkyo 2 ch reciever
                      by Jodeanss
                      Hey all, looking for some advice
                      First i have an Infinity sub amp from a ps10 that turns on, makes buzzing noise louder and louder till it shuts itself off. Noticed someone on ebay fixes them so it must be quite common.
                      Anyone have any idea on what goes out on these?
                      2nd i got a 2 ch onkyo tx8050 reciever that has never had any speakers hooked up, it was used as a controller for an old bose 5.1 amp they sold way back in the day, so only thing used was the 2ch preouts fed from the optical from tv. It turns on with half dim display and then protects...
                      04-04-2023, 08:07 PM
                    • Manlikeissak
                      M1 MacBook EFI/FMM unlock
                      by Manlikeissak
                      Hello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...
                      07-02-2024, 11:28 AM
                    • grimacelord
                      Pioneer VXS-D902S Reciever - Filter Capacitor Question
                      by grimacelord
                      I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
                      I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
                      I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
                      01-12-2023, 02:40 PM
                    • Batmanmax
                      NAD Model 7240PE Reciever schematic
                      by Batmanmax
                      Hello all,
                      I am looking for a schematic diagram to troubleshoot a NAD Model 7240PE receiver. Upon initial inspection, the unit has four (4) blown fuses (2) 4 amp, (2) 5 amp near the power supply section. Thank you.
                      11-28-2022, 06:06 PM
                    • Spanish_Rage
                      Subject: Vestel 17MB185Y (Daewoo 55DM72UA) — stuck on black screen with storage full warning, need firmware/recovery help
                      by Spanish_Rage
                      I have a Daewoo 55DM72UA smart TV (Android TV 11) that boots but never reaches the home screen. I'd really appreciate any guidance or firmware file.
                      Exact specs from the mainboard label:
                      • Manufacturer: Vestel
                      • Board model: VES660QNFH-N1-Z01
                      • Additional code: LGM VES660QNFH-N1-Z01_CN_56760_18DY
                      • Barcode: 2903502239 0107
                      • Serial: 23833611
                      • Made in Turkey, manufactured 23/29 (week/year)
                      TV model: Daewoo 55DM72UA, 55", 4K, Android TV 11 (2023)
                      Symptom:
                      • Power on → Evo logo → Android logo → boots into the OS
                      • Screen then
                      07-08-2026, 12:22 PM
