Gigabyte GA-8IPE1000-G v4 burnt & broken trace
  • jdryyz
    • Aug 2015
    • 16
    So this happened today.
    Click image for larger version  Name:	broken trace.jpg Views:	0 Size:	867.7 KB ID:	3923551
    Click image for larger version  Name:	top side.jpg Views:	0 Size:	762.6 KB ID:	3923554
    Click image for larger version  Name:	bulge and burst.jpg Views:	0 Size:	502.8 KB ID:	3923553
    Not sure if the popped and bulging caps contributed to the blown trace, however. Although, I am well aware this board comes from the bad cap era, it had no visible signs of trouble prior to me having started this retro PC project. In fact, all caps looked pristine with no bulging. And, yes, I am also well aware that not all bad caps need to have visible signs of trouble for them to be bad. Lesson learned.
    I think I was building the perfect storm with this event, as I had both an FX 5200 AGP card *and* a Voodoo3 3000 PCI (which gets REALLY HOT) installed and I had just finished adding a Sound Blaster Audigy2 card and finished up the drivers. At the moment I went to get additional properties on the newly added audio device, the computer shut itself off. Hmmm....
    After pulling the power cord and toggling the main switch, I only did a quick external spot inspection. The PC was somewhat in the dark (never a good idea during the build phase) and I didn't see anything wrong. I reconnected power and turned it back on...a few seconds later, another shut down and the magic smoke appeared from exactly where the broken trace was discovered (AFTER) I removed it from the case. I did not immediately spot the caps problem as I had a large Zalman CPU cooler obscuring the view.
    That trace is repairable (although it did heat up enough to almost fully dislodge itself from the PCB), and with these Gigabyte boards, there aren't too many caps to replace. I am hesitant to work with it again though.
    First I will drop another (sacrificial) P4 board in the case to be sure it still powers up, although I do not anticipate any power supply problem. Voltages will still be tested first.
