ASUS A8V Motherboard Bulging Cap Replacement
This topic has been answered.
  • SuperSullivan
    • Aug 2026
    • 5
    • Video Games, Retro Stuff, Electronics
    Hi there,
    This is my first question on this forum, so my apologies if this is formatted incorrectly or if there was a better section to post this.
    I recently acquired a desktop tower with an ASUS A8V motherboard, which is from around 2005 I believe. Unfortunately, there is a bulging capacitor just above the CD-ROM cable connector. From what I can see, this is a 6.3V 820uF cap. I'm not sure of the branding, as I can't see that well around the sides of the cap without taking the whole motherboard out.
    I do have an ESR meter, so I plan to move some stuff off my workbench and try to make room so I can test the caps and see if anything else is wrong.
    This post here seems to have a capacitor with the same value failing, but the thing is this is a different motherboard model, as I have a standard A8V, and as such I'm not sure whether or not the solution of a Nichicon HZ 6.3V, 2200uF cap would work for my board.
    https://www.badcaps.net/forum/troubl...me-experiments
    So, my hope is someone can help me find a good replacement for this capacitor. Apologies for the images, I haven't got the board out the case yet.
    Thank you!
  • Answer selected by SuperSullivan at 08-18-2026, 07:37 PM.
    andrewsawesomr
    • Jun 2022
    • 115
    • United States of America
    • Coding, Electronics, Music
    The cap is a United Chemi-Con KZG series cap. If it is indeed 820uF 6.3v, I would replace it with this: A750EM827M0JAAE008 KEMET | Aluminum - Polymer Capacitors | DigiKey / A750EM827M0JAAE008 KEMET | Mouser​ . I don't see a point in increasing the capacitance from the original design.
    • SuperSullivan
      SuperSullivan commented
      Editing a comment
      Thanks so much for the response! Yes it is in fact 820uF 6.3v. I'll order a few of the ones you linked, I appreciate the help!
    • SuperSullivan
      Editing a comment
      Also, after doing some more digging, seems like almost all the caps are United Chemi-Con KZG series caps. The capacitors you linked look perfect for the vast majority of them, but I think I should also replace the 4 or 5 16v 1000uF caps. Any chance you could recommend some good replacements? I was thinking these might work: https://www.digikey.com/en/products/...FC8X20/3563477
  • andrewsawesomr
    • Jun 2022
    • 115
    • SuperSullivan
      Editing a comment
    • SuperSullivan
      Editing a comment
  • SuperSullivan
    • Aug 2026
    • 5
    I took the mobo out of the case and got a better picture of the cap in question. I also used my ESR meter to measure the other caps and as far as I can tell (which isn't far) they seem fine. I should also have mentioned before that the mobo does work and boots even with this leaky cap. I'm still going to be replacing it though, for obvious reasons.
    • andrewsawesomr
      • Jun 2022
      • 115
      Yep, the caps you linked should work to replace the 1000 uF 16v ones on the motherboard. I would definitely replace the other United Chemi-Con KZG caps while you're at it.
      • SuperSullivan
        Editing a comment
        Will do, thanks again for all your help!
