How Many Caps Should I Replace?
  • sparkyrick
    • Nov 2014
    • 12
    My PC wouldn't POST this morning. I did some Googling and discovered this great site. I opened the case and found a bulging cap by the battery and was just wondering if I should replace every cap or just the one? It's an Elitegroup A780GM-A mobo.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: How Many Caps Should I Replace?
    Hello what is the brand and series of the caps, seen as one has failed its probably a good idea to change them all.
    • sparkyrick
      • Nov 2014
      • 12
      As for brand, all I can see without pulling the mobo out is OST on the cap's shrinkwrap.
      • sparkyrick
        • Nov 2014
        • 12
        While doing research this morning, I discovered someone posted this exact mobo on this site with the exact bulging cap.
        https://www.badcaps.net/forum/showthread.php?t=17253
          • 31213
          it may have been provoked, check inside your psu.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok well they are normally ok but can die with out any physical signs but replace that one and see if it fires up.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              For now, replace all four. The bulged one and its three friends that are the same as it. Make sure to use high quality capacitors from Panasonic, Rubycon or Nichicon. Harvesting them from similar locations on a dead board is okay, if you have one lying around.
              A working TV? How boring!
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Agreed, use good caps with the correct esr and you should hopefully be back in business.
                • sparkyrick
                  • Nov 2014
                  • 12
                  I'll get the correct ESR if ordered here, correct?
                  • sparkyrick
                    • Nov 2014
                    • 12
                    My B-I-L is an electronics tech at Plexus for 30+ years. He said replacing them wouldn't be a big deal and has all the good equipment at home to do it. I might just replace all of them if he is offering his services. I'm an electrician, not used to this tiny stuff, LOL!
                      master hoarder
                      • May 2008
                      • 12175
                      In this particular case, I doubt it.
                      See that coil next to those caps? That screams buck regulator right there. And if there is one thing OST caps hate, it's "high" ripple current from a buck regulator.
                      Looks like those OST caps are RLS series, and the bulged one is likely on the high side while the 3 others are probably all in parallel and on the low side.
                      Anything decent low-ESR will work here. Nichicon HM, HN, or HZ from the badcaps.net store is one excellent choice. Other choices are Panasonic FR and FM, United Chemicon KZE, Rubycon ZL, ZLH, ZLJ, and ZLG, Nichicon HD. Polymers will also more than likely work, but you might have to take some voltage measurements to see what is the highest voltage on those caps. Reason for that is because most 820uF polymers in 8mm diameter are 2.5V or 4V.
                      If this board is littered with those OST caps, the easiest solution would be to get appropriate Nichicon HM, HN, and HZ caps from the badcaps.net store and replace all of them, Then you won't ever have to worry.
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        • USA, Unsure of Planet
                        Since the PC is open and partly disassembled, if the P/S is more than 2 years old a 5 or 10 second look through the vents and fan of the P/S with a flashlight at the output caps and maybe the 5V Stby and small start-up cap could be 5 or 10 seconds very well spent.
                        PeteS in CA
                          by momaka
                          03-12-2025, 03:42 PM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • edith
                          Caps and how to find one to replace
                          by edith
                          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                          Thank you!
                          06-11-2023, 05:00 PM
                        • Mattz_GT
                          Which caps to replace: ECS P4M800Pro-M V1.0A
                          by Mattz_GT
                          It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
                          I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
                          Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
                          Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
                          PS. Additional diagnostic,...
                          01-22-2025, 12:12 PM
                        • rewease
                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                          by rewease
                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                          09-17-2023, 12:53 AM
