50V LARGE caps 18x22 max for Power Supply
  • Florida-Rob
    • May 2026
    Need help please, i need most capacitance as bulk to hold up after the bridge (12-24VAC = 34V peak+) as bulk
    max size is 18Dx22L mm
    considering KNSCHA DHG050M228N220S1AA (2200uF 50V 13mR 3.9A, 5000 hrs @ 105C
    The next best is 1800uF
    I see a bunch of SMT and PTH 1500uF
    i.e
    YAEGO CC0402JRX7R9BB102
    YMIN LKMJ2001H182MF
    Thoughts ?
    is KNSCHA ok ?
    spec says its AL foil + Ethanediol
    I have space for 2 caps, and need more than 300uF, hence why the 2 x 2200UF appeals
    I do have some poly caps aloingside, 2 x 120uF 10x10mm,
    NCC HHXC500ARA121MJA0G
    Panasonic EEHZC1H121P
    Lelon HBW121M1HTR-1010​
    Rob
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8887
    Why that strange capacitor size of 18x22mm?
    • Florida-Rob
      • May 2026
      We have a max height of 22mm, other than that, open.
      The best capacitance for thr 50V (or greater), seems to be 18x22
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8887
        What if you relocate the caps?
        or use 35V caps?
        I mean 24VAC = 34VDC.
        what kind of power supply is this? Linear or switcher?
        • Florida-Rob
          • May 2026
          max height of the box is 22mm, plus tolerence, sp 24mm for the cap
          its on a 24VAC rail, so 34V normal, plus curge, so needs to be 50V
          it feeds an active bridge, then a buck-boost 4 FET convertor.
          Hence think I have found the best I can get, hence need to knwo if this manufacturer is ok ?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8887
            Got no Idea if that cap brand is any good. Will it work? Probably. Is it a good quality part? Probably not. Capacitance alone isn’t the key here. The deciding factor is how much the 24VAC transformer can handle as an output. Not much good if you have the biggest caps, but only can use 30% because of the 24VAC transformer supply.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5401
              • New Zealand
              • Electronics and computer repair
              is KNSCHA ok ?
              2x 2200uF is a lot more than 300uF
              Why not go down in value a bit so the sizing is less restricted, and source something from a known-good brand like Panasonic?
              Never heard of KNSCHA, never seen them in anything, it's not even a pronounceable word!
              Can't say I'd trust them to last.
              -David VanHorn
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
                03-31-2024, 02:12 PM
              • Sacajuoy
                Samsung UE46C6735 turns off intermittently - power supply unit PD46AF1 (BN44-00357B) real fault.
                by Sacajuoy
                I've had this Samsung UE46C6735 for many years now and Samsung early on replaced the power supply under warranty explaining that there were design flaws as well as bad capacitors. I worked in electronics design industry at the time and was well aware of the bad capacitor situation.
                Now, the TV worked flawlessly for many many years but in recent years it developed a habit of turning on and off and in the last week it never turned on properly, just blinked on for a short moment and I could hear relay clicking for every try to turn on. At first I was looking for a new TV so on the day...
                09-12-2026, 12:18 PM
