What is the value of C553
  • Jackching
    • May 2017
    • 159
    I smelled burning coming from my bookshelf stereo then it wouldn't turn on. I pulled it apart and seen some burns near this cap so i pulled it. I'm getting a reading of about 90nf from it each way. Are these polarized? How am I supposed to know the value of it? Also how am I supposed to know which size to order if i get one? Maybe it's not even bad.
  • R_J
    • Jun 2012
    • 9775
    • Making Money
    You can start by posting the Model number, maybe there is a schematic, C553 is a mlcc 0.1µf/50v not polarized, unlikely to be the problem. It is across the 36v power supply output. If you do not have +36 volts, I suspect a problem in the primary side of the power supply
    I will take a guess that it is a Sony HCD-ECL7D
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8887
      I suppose you can take that MLCC cap out if you want for testing purposes. All 36V and GND solder joints look like to me.
      • Jackching
        • May 2017
        • 159
        Yes that is the model. I had this apart now 5 times and got it going again with a step up transformer and that that worked for a few years up until now. I think it had the problem of not getting 36 volts to some point. I might just throw it out.
        Those solder joints do look piss poor
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8887
          Hmm… I looked at the service manual and the MLCC cap is a 50v 0.1uF xr7.
          the PSU is easy too… I’d call that an easy Sunday afternoon repair.
          • R_J
            • Jun 2012
            • 9775
            • Making Money
            If a higher input voltage makes it work, start by replacing CE505 (47µf/50v) in the primary
            • Boardview and Schematic Bot
              Acer TravelMate TMB118-R-C553 Hybrid (2-in-1) Spin B1 Specification for Upgrade or Repair
              This specification for the Acer TravelMate TMB118-R-C553 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TMB118-R-C553 boardview and TMB118-R-C553 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 08:40 PM
            • chth96
              by chth96
              06-02-2024, 07:31 PM
            • bulkchart32
              i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
              by bulkchart32
              i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
              06-16-2025, 03:09 AM
            • jshhh
              Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
              by jshhh
              Hi guys,
              I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
              03-26-2025, 07:05 PM
            • GardevoirForEver
              Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
              by GardevoirForEver
              I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
              Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
              The motherboard of my ASUS...
              11-15-2025, 04:30 PM
