DFI Lanparty NF3 250GB recap help
  • laskr1999
    • Nov 2025
    • 13
    • Hungary
    Hello!
    I'm currently trying to recap my rare board, and would like to have some assistance from an experienced user. Currently I think that I could match some caps, but for some I couldn't find any good replacement yet.
    This is the board, color coded:
ID:	3871850 And without colors+vrm:
ID:	3871852 Click image for larger version
    And the caps i have+replacements I found:
    Chemi-con:
    KZG:
    6x - 6.3V 3300uf - dark red --->RPF1014332M006K
    4x - 16V 1500uf - light red --->16ZLQ1800MEFC10X20
    1x - 16V 470uf - Brown --->
    5x - 10V 1000uf - lime --->
    KMG:
    18x - 16V 100uf - Blue --->16ZLQ150MEFC5X11
    KMA:
    4x - 16V 100uf - white --->ESS107M016AE2EA
    Nichicon:
    HM(M):
    20x - 6.3V 1000uf - pink --->
    Thanks in advance!
    • 32069
    add the cap diameters please.
    the dark red ones should be polymer to handle the task
    you wont find 3300uf -afaik, but 2000uf polymer should be good.
    • laskr1999
      • Nov 2025
      • 13
      • Hungary
      I found 3300uf already added after the arrow. The low side found the same specs, higher rms polycap, high side just way better, linked that too there. I would like to have a stable oc mobo, which have similar/little better specs, but like at hm ones, i could find way better polys only.
      Sizes:
      Chemi-con:
      KZG:
      6x - 6.3V 3300uf 10x25mm - dark red --->RPF1014332M006K
      4x - 16V 1500uf 10x20mm - light red --->16ZLQ1800MEFC10X20
      1x - 16V 470uf 8x11,5mm - Brown --->
      5x - 10V 1000uf 8x15mm - lime --->
      KMG:
      18x - 16V 100uf 5x11mm - Blue --->16ZLQ150MEFC5X11
      KMA:
      4x - 16V 100uf 6.3x7mm - white --->ESS107M016AE2EA
      Nichicon:
      HM(M):
      20x - 6.3V 1000uf 8x12.5mm - pink --->
      OR
      KZG 6.3V 1000uf 8x12.5mm - pink (same mobo but the other ones has this over nichicon)
      • spithink
        • Apr 2026
        • 14
        • Hawaii
        I would recommend to go all solid caps. Then you most likely wont have to bother any time again with the caps. Like stj told, thanks to solid caps, you can often go lower capacity and still have a better electrical result then when the board was new. Kemet caps are also some you can take into the list if you cant find everything solid from Chemi-con and Nichicon.
        Do not forget to replace the thermal component from the south bridge/north bridge for something modern like Arctic Cooling MX7.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3298
          • Singapore
          Originally posted by laskr1999
          KZG:
          kzgs are a known bad series and need to be replaced on sight. the polymer cap series that was famously used for overclocking was the sanyo oscon sepc series but now its been sold to panasonic. so usually they use 820µF 2.5v there. your mobo uses filtering coils with 4-5 turns for the cpu vrm so it uses a medium-high switching frequency so it should be able to handle polymers with ultra-low esr rather than high capacitance without problems. the issue is that those polymers are in high demand and so are often out of stock. worse, there's several different versions of them with different size, esr and ripple. so getting the right version is important to maximize overclocking potential. furthermore, its an 8mm diameter cap while the ones on your board are 10mm in diameter. refer to the attached datasheet.
          KMG:
          KMA:
          these small caps dont cause a problem. they are used for audio, lan, fan, general purpose filtering etc. and dont cause problems. save yourself some time and money by skipping these.
          Nichicon:
          HM(M):
          OR
          nichicon hm caps from 2002-2005 are known to be bad due to an oopsie from the manufacturer pertaining to cleaning fluid contamination caused by the sars epidemic during that time. look at the date codes on yours if they are 02 to 05. this board was made during that time i believe and so need to be replaced. the good news is that they are used for filtering the minor rails and so any normal low-esr cap can replace them. i usually replace them with panasonic fr (a 6k to 10k hours cap series) which is readily available. equivalent series from other manufacturers are rubycon zlh and chemicon kzm.
          the brown and lime colored caps in your photos seem to used for usb filtering and agp/pci 12v rail filtering so no need to polymod those.
          also once u are done with the recap, dont forgot to add mosfet heatsinks for the cpu vrm. vrm cooling is important when overclocking and is often overlooked. there are 6 of them on the cpu vrm area.
          EDIT: i would also add a 120-140mm fan to the side panel blowing air at the pci slot area to keep the chipset heatsink cool as the nvidia nf3 shitset may be affected by the bumpgate problem so keeping it cool below 60°C is necessary if u want the board to last!
          Last edited by ChaosLegionnaire; 06-04-2026, 09:44 PM. Reason: more cooling options and typo fix.
          • laskr1999
            DFI Lanparty NF3 250GB complete recap help
            by laskr1999
            Hello!
            I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
            I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
            I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
            - 20 x Nichicon 1000uF 6.3v HM 105C
            - 5 x Chemi-con KZG 1000uF 10V
            - 1 x Chemi-con KZG...
            11-25-2025, 03:27 PM
          • laskr1999
            DFI Lanparty NF3 250GB recapping
            by laskr1999
            Hello!
            11-25-2025, 04:44 PM
          • laskr1999
            DFI Lanparty NF4 Ultra-D recap help
            by laskr1999
            Hello!
            I have got multiple DFI Lanparty NF4 Ultra-D motherboards, that I would like to recap for longevity. Can someone please help to find alternatives, with quality caps(I see some noname on it, so I would like to get from quality brands)
            As far as I see, I have 69 caps that are on the mobo. This mobo for example had very little usage, so the caps are not yet gassed out like on the other ones. I would like to go with poly where its possible, and keep the same size where I can only put normal ones.
            I attach both with and without marked caps pics to see it better.
            12-19-2025, 12:18 PM
          • Boardview and Schematic Bot
            HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
            This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
            09-12-2024, 03:36 PM
            HP ProBook 470 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 470 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 470 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 470 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
            09-06-2024, 08:52 AM
