Confused with this ceramic capacitor
  • Billathome65
    • Apr 2026
    • 18
    • Growing Veg, walking the dogs and messing with sparky things Amplifiers etc.
    This orange capacitor is grounded on both legs when tested with a multimeter to ground point. But when removed it is good on the TC1 tester.
    I check the trace and they are both soldered into the ground trace and have been when it was working.
    Shurly if this was soldered to ground on both legs this would effectively render it as a short?
    What am I missing here?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    Are you sure you are measuring the correct points?
    Are you sure you don't have something else shorted in parallel with the capacitor?
    -David VanHorn
    • R_J
      • Jun 2012
      • 9775
      • Making Money
      If you check the schematic, you will see both ends connect to ground, looks like it is only the Europe models that use C70
      The two ground points get connected between W1 pin3 to W2 pin4, likely has to do with high frequency noise decoupling in the Europe models
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • CGm
        ASUS TUF FX506HCB DANJJBMB1A0 missing ceramic capacitor near CPU/GPU VRM
        by CGm
        I am currently working on an ASUS TUF FX506HCB motherboard (DANJJBMB1A0 REV:A) with a missing ceramic capacitor near the CPU/GPU VRM area. The area also appears to have been worked on previously.
        I am trying to identify the exact name, value and voltage rating of this capacitor because the laptop recently stopped powering on.
        If anyone has a boardview or schematic with the correct component values for this motherboard, or can help identify this capacitor, I would greatly appreciate it.
        I attached photos of the motherboard and...
        05-07-2026, 05:53 PM
      • NuclearSpartan
        Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
        by NuclearSpartan
        I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
        The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
        I don't see any other visible damage anywhere else on the board....
        11-14-2024, 02:32 PM
      • Hoanghtran99
        Samsung Hw-N850 soundbar. Help me indentify this ceramic capacitor please.
        by Hoanghtran99
        Hi guys, im learning how to fix my Samsung Hw-N850 soundbar. I found a blow up high voltage capacitor but i cant found its specs, its indentify on board is called CA810, the power board code is AH4400339C
        Hope someone can help me pick the right capacitor, thank you
        09-05-2026, 10:42 PM
      • joetristan
        Tantalum capacitor burning out
        by joetristan
        I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
        At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
        I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
        I do not understand why the tantalum capacitor burns up?
        02-11-2026, 03:43 AM
