Unfamiliar Capacitor Markings - What Value Are They?
This topic has been answered.
Answer selected by RetroComputingGrotto at 04-24-2026, 05:12 AM.
by joetristanHello,
I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
I do not understand why the tantalum capacitor burns up?-
by jkucukovI have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
Thanks,... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by woodboy971Hello everyone,
I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
My issue is that I cannot identify...3 Photos-
by Quadro1000Hi,
I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
So to have full functionality and no instabilities I want to replace it with a new one.
So I need to know the value and voltage of C55 to replace...-
Channel: Schematics and Boardviews
- Loading...
