Need advice on direct replacement filter caps
  • Billathome65
    • Apr 2026
    • 18
    • Growing Veg, walking the dogs and messing with sparky things Amplifiers etc.
    X2 Elna 7500Uf 71v caps one reading 3.997 the other OL
    As they are discontinued are there other direct replacements I can use?
  • redwire
    • Dec 2010
    • 3972
    Measure the cap's size HxWxD and # of pins, pin spacings. Sometimes these are pretty tight for size and alternates harder to find. The footprint might be easy to find. Height - watch the enciosure lid has room.
    Beware many fakes of these out of china, they have a small cap stashed inside the can and you can shake and rattle them. The OL one I would take it apart as that is a bit weird unless it corroded internally.
    • apholabi
      • Nov 2020
      • 9
      • italy
      You will never find that value, it is currently out of standard, it is probably a custom product, put 8200 microfarad 100 volts, you can go ahead, if the old capacitor has three pins one is not connected it is only a support for the capacitor.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5401
        • New Zealand
        • Electronics and computer repair
        Yeah 7500uF is not a standard value (anymore). Nor is a 71V rating. They must be pretty old!
        You can use a higher voltage rating without issue. Going slightly higher to 8200uF should be fine, but don't increase the value excessively. Higher capacitance values will cause a higher inrush current when first powered on, which puts more stress on other components.
        As others said, be careful with the dimensions. Sometimes there's not much space, but luckily the older capacitors are often physically larger than their modern equivalents, and replacements are easy to fit even with higher values. I recently replaced the filter capacitor in my old valve radio, and the electrolytics I used are about 1/3rd (together) the total volume of the original multi-section capacitor!
        One important thing to consider also is the ripple current rating. If you can get a datasheet for the originals, find out what the rating is and get replacements with the same or higher rating. If you can't find the original specifications, just use whatever has the highest rating you can fit in. Then they will last longer.
        -David VanHorn
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
        • rewease
          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
          by rewease
          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
          09-17-2023, 12:53 AM
        • crosswinds
          Assistance with identifying replacement caps on ASUS P5VDZ-MX
          by crosswinds
          So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
          Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
          Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
          Its a ASUS P5VDZ-MX board.
          I would really appreciate some assistance on what the best replacement caps would be for these:
          Panasonic(M)...
          04-17-2024, 04:25 PM
        • HectoPascal
          Replacement caps ok? (smoothing caps, PSU heating controller)
          by HectoPascal
          Hallo,
          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
          Nichicon should be 'VY' series (linked).
          I couldn't find anything about Samwha...
          09-06-2023, 08:30 PM
        • bohaboha
          PHILPS OUS 656521/12 Polarizing Filter ADVICE
          by bohaboha
          Hello everyone have this set with burnt points and some small cracks in the bottom edge of the Polarizing Filter it is almost glass transparent that I was going to try to fix with the car windshield repair agent so try does not mean succeed
          my question, can i replace it with one that is not transparent the usual white ones
          Maybe pictures explain better
          IT IS TRANSPARENT i see it now so it will be a repair try att first
          have anyone here sold Polarizing Filter? how to package a thing like that ? looks impossible without a very expensive Device
          any idea are we...
          12-14-2025, 08:01 AM
