Can You Help Me Correctly Identify This Capacitor
This topic has been answered.
  • RetroComputingGrotto
    • Aug 2023
    • 120
    • Retro Computers (and fixing modern laptops too).
    I have a Compaq Contura 25/4 laptop on my workbench at home at the moment (yes it's a 32 year old laptop) and when I tested it I saw some magic smoke come from it!
    Fortunately the power board is separate to the main motherboard so hopefully this will make it easier to repair..
    Click image for larger version  Name:	20260327_140315927_iOS.jpg Views:	0 Size:	559.9 KB ID:	3846670
    Here is a close up of the blown capacitor:
    Click image for larger version  Name:	20260327_143514000_iOS.jpg Views:	0 Size:	63.1 KB ID:	3846669
    I'm assuming it is a 2.2µF 25V ceramic capacitor that I need to order a replacement of? Not sure if it's a 'standard' one or a tantalum one for example so looking for your expertise and experience on this one!
    It goes without saying (but I'll say it any way) I will replace all the electrolytic capacitors on the board whilst I have it out of the machine.
  • Answer selected by RetroComputingGrotto at 03-28-2026, 01:25 AM.
    m1ch43lzm
    • Mar 2019
    • 3589
    • Peru
    Looks like a 2.2uF 25V tantalum capacitor, your guess is correct
    Tantalum caps when they fail they go
    • m1ch43lzm
      • Mar 2019
      • 3589
      • Peru
        • Aug 2023
        • 120
        Thanks for confirming my suspicions - much appreciated 😎
          • Aug 2023
          • 120
          The postman's been!
          This is my blog on what I'm attempting to repair: https://www.retrocomputing.co.uk/202...q-contura.html
          I've now replaced the caps and just need to test it to see if anything else is wrong with the board, but I'm hoping it's just the caps as it is 32 years old this laptop!
            • Aug 2023
            • 120
            We have picture!
            So pleased my repair has brought this 32 year old laptop back to life - worth attempting to repair the hinge now and if that's successful I need to replace the 120MB IDE hard disk as that's just clicking!
              • 32069
              next time use a 35v part.
              25v is too close to the charger voltage for comfort.
              • joetristan
                Tantalum capacitor burning out
                by joetristan
                I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
                At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
                I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
                I do not understand why the tantalum capacitor burns up?
                02-11-2026, 03:43 AM
              • OneRefresh
                MacBook Air A2337 (Logic Board 820-02016) - Blown tantalum capacitor and dead component near battery connector
                by OneRefresh
                I am troubleshooting a MacBook Air M1 Model A2337, Logic Board 820-02016 that suddenly went completely dead with no signs of life, no trackpad click, no display.
                Here is what I have done and found so far.
                Initial testing involved trying a soft reset and testing different USB-C chargers including a 75W PC charger, but the board pulled no current and remained unresponsive.
                Battery isolation was the next step. I opened the Mac and disconnected the battery connector. Testing on wall power yielded the same result, it was totally dead....
                06-04-2026, 01:45 PM
              • devsigner
                identify capacitor for MacBook Pro with rare logic board 820-02037-06
                by devsigner
                Hi
                While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
                resistance tests show a rising resistance value, indicating a capacitor.
                The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
                i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
                It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
                11-28-2025, 01:39 PM
              • EpicFix
                Can anyone help me identify theses iPad Pro 11" (A2759) capacitor values
                by EpicFix
                Working on an iPad Pro (A2759) with no touch. These components highlighted are shorted near one of the screen connectors (I'm assuming its for flex cable that handles touch). Can anyone help me with their values (C379, C1106 and the big one has no label). Please see attached picture. Any help greatly appreciated. Thanks in advance.
                07-30-2026, 02:54 PM
              • jkucukov
                ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
                by jkucukov
                I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
                I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
                How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
                Thanks,...
                08-11-2026, 09:00 AM
