Old caps...
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Old caps...
    Originally posted by eccerr0r
    Ah. someday I should get one to tear apart to see what's inside, but at the moment things are working about as expected... Though I haven't decided yet whether I should gut the old electrolytic and put two modern caps inside or not.
    Your mini fire bottles would be much more happy with new caps in it.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Re: Old caps...
      I would replace the old electrolytic with new caps.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Re: Old caps...
        I partially restuffed the 20+20 cap as it wasn't showing any capacitance on my LC meter. Took a heat gun and melted out all the wax and put two caps inside, mostly using the shell to hold the caps in place versus letting them dangle around.
        I just realized this sig generator does not meet UL standards... wow...
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
          by momaka
          03-12-2025, 03:42 PM
