Tantalum capacitor burning out
  • joetristan
    • Feb 2026
    I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
    At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
    I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
    I do not understand why the tantalum capacitor burns up?
    • 32055
    a voltage spike or reverse polarity spike will blow tantalum's
    where did you get it? i'v only seen 16v and 25v - 20v sounds strange
    • Agent24
      I see dead caps
      • Oct 2007
      • 5401
      • New Zealand
      • Electronics and computer repair
      Dumb question but did you put it around the right way? At first glance and without experience, one may assume the tantalum is marked with the stripe denoting the negative lead, like an aluminum electrolytic. But on a tantalum the stripe indicates the positive lead.
      What kind of circuit is this in? Is it something (like a switching regulator) that may cause voltage spikes?
      I agree with stj, a 20v rating sounds odd. Is this a very old capacitor? I've seen very old dipped tantalums rated at odd voltages. It might have just failed due to old age in that case.
      I also wonder, did you get it from some cheap place like Temu? I would not trust the quality of no-brand parts from there in any case.
      -David VanHorn
        • 32055
        Temu is real?
        i thought it was just a CIA project to make china look bad!
          • 32055
          "Unapproved"?
          that's a new low.
          i'll be spending more time on eevblog at this rate.
          • m1ch43lzm
            m1ch43lzm commented
            Editing a comment
            Approved your previous post
        • Agent24
          I see dead caps
          • Oct 2007
          • 5401
          • New Zealand
          Maybe the keyword Temu sets off a spam filter or something?
          Just another thought - another issue you can have with cheap unbranded components is a higher chance of polarised parts being marked incorrectly. So possibly the polarity stripe is on the wrong lead!
          -David VanHorn
          • Remus96
            GPU power rail short circuit (likely blown MLCC capacitor) – ASUS TUF FX506IU (Quanta BKXB)
            by Remus96
            Hi everyone,I ran into an issue where my ASUS TUF FX506IU suddenly shut down and wouldn't power back on. Despite only having basic electronics knowledge, I decided to diagnose the board myself.
            So far, I've tracked down the issue to a short on the GPU power rail. After desoldering the PR524 current shunt resistor to isolate the GPU circuit, the main VIN rail cleared up (no beep/open circuit to ground on the VIN pad in continuity mode). However, the short to ground is still present on the VIN_GPU side.
            Visually, none of the ceramic capacitors (MLCC) appear damaged, cracked, or discolored....
            09-24-2026, 12:46 PM
          • OneRefresh
            MacBook Air A2337 (Logic Board 820-02016) - Blown tantalum capacitor and dead component near battery connector
            by OneRefresh
            I am troubleshooting a MacBook Air M1 Model A2337, Logic Board 820-02016 that suddenly went completely dead with no signs of life, no trackpad click, no display.
            Here is what I have done and found so far.
            Initial testing involved trying a soft reset and testing different USB-C chargers including a 75W PC charger, but the board pulled no current and remained unresponsive.
            Battery isolation was the next step. I opened the Mac and disconnected the battery connector. Testing on wall power yielded the same result, it was totally dead....
            06-04-2026, 01:45 PM
          • robna
            Lenovo ThinkPad L13 Yoga Gen 3 (21B5) – dead after USB-A got 20 V from Dell D6000 dock, VBUS-GND short ~0.45 Ω
            by robna
            ThinkPad L13 Yoga Gen 3 (Intel, type 21B5), FRU 5B21J15858, [board no. 213037-1]. No schematic found.
            What happened: I connected a Dell D6000 dock to the laptop's USB-A port using a USB-C to USB-A phone charging cable (USB-C end at the dock, USB-A at the laptop). The dock presumably put PD voltage (up to 20 V) on that cable. There was a bang and a slight burning smell.
            Symptoms since then:
            Laptop does not power on, the power button does nothing.
            It still charges, the charging LEDs light up with the charger connected (USB-C PD seems alive)....
            10-17-2026, 06:11 AM
          • Boardview and Schematic Bot
            Huawei P9 Plus Schematics & Boardview
            Huawei P9 Plus WCDMALTE 8 12 13 20 26 28 29 (MMMB) Front Modular Circuit block diagram.pdf
            Huawei P9 Plus WIFI Circuit block diagram.pdf
            Huawei P9 Plus CPU vcc U1101.U1301Circuit block diagram.pdf
            Huawei P9 Plus frame Circuit block diagram.pdf
            Huawei P9 Plus RF Front End Switch Main ANT Circuit block diagram.pdf
            Huawei P9 Plus U3902 LTE Diversity Circuit block diagram.pdf
            Huawei P9 Plus CDMA RFIC Circuit block diagram.pdf
            Huawei P9 Plus power supply U1001Circuit block diagram.pdf
            Huawei P9 Plus...
            10-20-2026, 02:50 PM
          • jkucukov
            ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
            by jkucukov
            I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
            I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
            How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
            Thanks,...
            08-11-2026, 09:00 AM
