3300uf 16v, 10x30mm cap options
  • staze
    • Mar 2008
    • 43
    • Computers and Electronics.
    Got a Dell powersupply that has blown output caps. They're Samxon brand, and they're stupid 10mm diameter which is annoyingly difficult to find. I think they're GK series (they're labeled GK(M)).
    I'm trying to find some type of replacement, but I can't find anywhere to buy Samxon caps, and the only caps that seem to be available in that size are only rated at 1000hrs (EKMG160ELL332MJ40S).
    I tried dry fitting some 12.5mm diameter caps, but they won't fit.
    Any input on options for this, or just suck it up and buy the 1000hrs Chemi-con ones.
    Thanks!
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    The hour lifetime rating is not so bad since that's the rating for running at the max rated temperature, in this case 105 degrees - the hours increases as operating temperature decreases.
    Then again Dell likes roasting capacitors with atrocious airflow so...
    Your bigger problem is that the EKMG160ELL332MJ40S is only rated for 1170mA ripple, while the Samxon GK in that size would be around 2400mA or more, and in 10x30mm it sounds like custom order too, since it's not in the datasheet, so not surprising you can't find them easily.
    Hopefully someone else can give some more help, maybe you can use polymers somehow, but I'm not sure the calculations for that (if possible).
    Are you sure you can't stuff 12.5mm capacitors in? Not even by desoldering and tilting other components away? Photos would be helpful...
    -David VanHorn
    • staze
      • Mar 2008
      • 43
      Thanks! Yeah, they run into each other... I could _probably_ make it work, but it'd be pretty sketch. I found some "jcco" on amazon that look like they are similar/same spec.
      I also found that with the Samxon GK's... they were listed as 12.5 in that size. =/
      I couldn't even find a place to order Samxon caps... did they change their name to something else, or do they only sell to OEMs?
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 820
        • Electronics & Lighting (Mostly Vintage Lighting)
        LCSC Does offer Chemi-Con caps that should in theory work based off the specs listed on the website: https://www.lcsc.com/product-detail/C18164649.html
        While I haven't bought those specifically, I have bought a bunch of other name brand caps off LCSC over the years and can say that the parts they sell are (as far as I can tell) legit.
        I'm not a expert, I'm just doing my best.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5401
          • New Zealand
          A lot of OEMs like to get custom runs of capacitors in taller and narrower sizes, it seems. I've seen plenty of PSUs where off-the-shelf replacements were always larger in diameter. Fortunately you can usually jam them in somehow.
          Samxon isn't a terrible brand, although IIRC their old GF series were pretty bad.
          I have no idea what the quality is for "jcco" from Amazon is. Did you mean JCCON? I can find a lot of capacitors with that brand on AliExpress and Amazon. They certainly seem to be "popular".
          Would they work? Well... probably. Unless the ESR and RCR is way off what they claim. The question is how long will they last... I expect probably not as long as the original Samxons, but the only way to know is to try them and see.
          I can't find a website for them or any obvious datasheets, which doesn't inspire much confidence. Can you give a link to where you found them?
          Found a thread here: https://www.badcaps.net/forum/genera...950-jccon-caps but it doesn't say much.
          Even the general purpose Suntan brand capacitors sold by Jaycar here have a website. https://www.suntan.com.hk/
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 5401
            • New Zealand
            Those look like a much better choice than the JCCON for sure. LCSC does seem to be pretty reliable. I haven't bought capacitors from them, but the parts I did buy have all been okay. I get the impression they often sell off surplus parts, so I'd expect these to be genuine.
            Assuming 35mm high capacitors will fit your PSU!
            -David VanHorn
            • Agent24
              I see dead caps
              • Oct 2007
              • 5401
              • New Zealand
              I had a look at https://otzovik.com/review_7950761.html as mentioned in that other badcaps thread. Google Translate is helpful
              The person who wrote that review seems to think these capacitors are good, and states "JCCON is a fairly reputable Chinese capacitor brand, producing high-quality, branded products."
              And yet there is still no mention anywhere of a website for the brand in question, nor really anything to back up these claims of quality, nor any datasheets.
              Go figure.
              They do some measurements like capacity, leakage, and ESR, and all seem to be fine. However the capacitors they are reviewing are low frequency filtering capacitors for linear power supplies in audio amplifiers. And anyone can make a general purpose capacitor that works okay, so the fact they measured alright doesn't mean a lot. There is also no long-term reliability testing in the review, so we don't know how they held up.
              I'm not convinced the JCCON is anything special, myself. Even the worst-of-the-worst Sacon FZ technically did function as capacitors .... for about five minutes....
              -David VanHorn
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3298
                • Singapore
                chemicon cst series? which is according to the datasheet on that link. that must be a custom order series right? esp. since the photos of it show just a 'w' for the series. i guess thats how chemicon does the printing for custom order series? its pretty decent tho, the datasheet says an endurance rating of 4k hrs. could i just stuff panny fs 2200µF 16v Ø10x25mm caps in there instead and get away with it?! haha~
