Help id Capacitors in HP Pavilion 14-AV006la
This topic has been answered.
  • modestoros
    • Feb 2022
    • 32
    • Chile
    Hi
    I'm trying to repair the laptop, which has water damage, but I found 2 capacitors that were damage. I looked up the Boardview software and the capacitor is C7713 and C3022
    Click image for larger version  Name:	image.png Views:	0 Size:	16.8 KB ID:	3804703Click image for larger version  Name:	image.png Views:	0 Size:	21.0 KB ID:	3804704
    I managed to get the schematics but I can't figure out the value of the capacitor, the image below shows the components.
    Click image for larger version  Name:	image.png Views:	0 Size:	23.8 KB ID:	3804705Click image for larger version  Name:	image.png Views:	0 Size:	9.6 KB ID:	3804706
    I want to buy remplacements I will try the site www.mouser.com but I don't know how to search both components.
    Thanks in advance for all the help
    Best Regards​
  • Answer selected by modestoros at 01-18-2026, 06:34 PM.
    andrewsawesomr
    • Jun 2022
    • 117
    • United States of America
    • Coding, Electronics, Music
    The first capacitor is 100 nF at 10V, the second capacitor is 10 pF at 3 kV. In the second one, the size is given (1808, 18*8) and you can assume it's a ceramic capacitor by the capacitance. From there, you can go to an electronic components distributor, go to the ceramic capacitors category, Select size 1808 (in), select voltage 3kv and up (select the 3kv, scroll to the end of the list, hold shift, and click the last available option), and capacitance 10 pF. For example, here is a correct replacement: https://www.mouser.cl/ProductDetail/...DQE4nP0A%3D%3D . For the other one, you will have to figure out the type, size, and potentially ripple current/ESR.
    • andrewsawesomr
      • Jun 2022
      • 117
      • modestoros
        • Feb 2022
        • 32
        • Chile
        Thank you so much for your help
        • modestoros
          • Feb 2022
          • 32
          • Chile
          Hi
          It's ok the selection I made, is missing something?
          thanks in advance
          • andrewsawesomr
            • Jun 2022
            • 117
            Originally posted by modestoros
            Hi
            thanks in advance
            Click image for larger version  Name:	image.png Views:	0 Size:	56.6 KB ID:	3808029
            That's fine. The only thing I would recommend is that when you make your selection with voltage, select the 3kv, scroll down to the end of the voltage list, hold shift, and click on the last available voltage (10kv in this case). This gives you more options. Click image for larger version
            • modestoros
              • Feb 2022
              • 32
              • Chile
              Thank you for your help andrewsawesomr in tolerance knowing your expertise what value would you chose?
              • andrewsawesomr
                • Jun 2022
                • 117
                The voltage value on that cap doesn't matter as long as it's at least 3kv. I just recommended that you include multiple voltage values in the search so that you can see all the compatible replacement parts. The part I linked is the cheapest replacement part from Mouser.
                • modestoros
                  • Feb 2022
                  • 32
                  • Chile
                  Thank you in tolerance knowing your expertise what value would you chose?
                  • andrewsawesomr
                    • Jun 2022
                    • 117
                    You don't have to worry about the tolerance field in this case.
