Rubycon MCZ and MBZ capacitor reliability (2000-2010)
  • Flame_GL713
    • Jan 2026
    HI everyone, I'm new to the forum, and somewhat of a rookie when it comes to electronics/soldering so forgive me if this is posted in an incorrect category. What I want your guys' opinions on is the reliability of Rubycon MCZ and MBZ. The main reason for this is to determine if the ones in some of my Xbox 360 motherboards are "silently" failing, as I've heard some people mention with these series.
    Additionally, I have the chance to buy some NOS MBZ caps from 2009, which admittedly is probably not the best idea, but I would still like some general consensus as I haven't come across a single MCZ/MBZ cap that has visibly bulged in any of the console motherboards that I've come across. I briefly remember some threads mention the silent failure of one of the series but I can't remember if it was MBZ, or MCZ that had the issues.
    All of your guys' wisdom is much appreciated
    • 32069
    if they get too hot they vent,
    if they look o.k. then they are probably fine.
    if you ever need to replace them then you use polymer caps.
    no other electrolytic comes close to MBZ/MCZ and they have not been made for a very long time.
    so any you see for sale are ancient or fake.
      • 32069
      btw, powering up electrolytics with esr that low after many years - just wear safety glasses.
      i'll leave it at that!
      • Flame_GL713
        • Jan 2026
        Ok, these were the possible NOS ones that I was considering. Yes, I know Aliexpress is sketchy, but they do look real right? Is there a definitive way to know simply based on looks alone? They have a date code of the 36th week of 2009.
        • Flame_GL713
          • Jan 2026
          Also, I just found this on the caps wiki site. Apparently, all MBZ and MCZ have bad electrolyte???
          • Wester547
            • Nov 2011
            • 1273
            • USA.
            • Electronics.
            “All MBZ and MCZ have bad electrolyte” is a bit of a generalization. MBZ were good if kept cool. MCZ were much more sensitive to heat. KZG from 2007 or earlier should not be trusted, ever. The advice to replace ultra low ESR electrolytics with polymers is sound. 1500µF 16V Rubycon MBZ would be good if genuine, but I would not order anything from Aliexpress (chances are high they are counterfeits). On an Xbox 360 motherboard, depending on the revision, I would be more worried about the state of the GPU underfill than the capacitors (unless they are Sanyo WF)…..
            • Agent24
              I see dead caps
              • Oct 2007
              • 5401
              • New Zealand
              • Electronics and computer repair
              It's impossible to say. Yes they can look real, but from China that doesn't mean much. The land of fakes aplenty. Also, the photo can be NOS but they send you something else. No guarantees the photo is of the actual item. Known good polymers from a known good distributor is a much better idea. But you're welcome to buy and test the AliExpress ones for our amusement!
              -David VanHorn
              • Flame_GL713
                • Jan 2026
                Ok, so here's an example image of a Xenon Xbox 360 motherboard because I want to mention a few things.
                The caps highlighted in green are for the 12 volt rail, and are normally Nichicon HN or Rubycon MCZ from the factory. (In the example image they are the Chemicon ones) Its interesting that you mention that MCZ was more sensitive to heat, so do you think they purposely decided to not use MCZ for the VRM caps highlighted in blue in the image, as they are less heat resistent? (That area around the heatsinks gets much hotter)
                The caps highlighted in blue are for the CPU/GPU Vrms, and are normally Nichicon HZ. (In the example image they are Rubycon MFZ) So, my question is can I use Rubycon MCZ to replace the VRM caps? Or should I look for replacements that have better heat resistance?
                The way I see it, MCZ should be fine for the 12v rail, as that area will not get nearly as warm as the area around the heatsinks, and since Microsoft used them there they should be alright.
                But for the VRMs, I'm not so sure. The main reason I think they would be good there is because of their Ultra Low ESR, but I could be wrong.
                  • 32069
                  if they need replacing because they have burst then use NEW polymer cops.
                  dont buy old stock that could explode when you power it up. ( seen it happen personally )
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5401
                    • New Zealand
                    That's why you should check leakage on NOS electrolytics and reform them if necessary
                    -David VanHorn
                    • Wester547
                      • Nov 2011
                      • 1273
                      • USA.
                      • Electronics.
                      This appears to a Xenon motherboard, whose GPU runs very hot and is notorious for the underfill defect…..
                      Rubycon MFZ is similar to Rubycon MCZ. I see Chemi-con KZJ on this board too, another unstable series from Chemi-con. At this point, it may be wise to replace the VRM input and output capacitors with new polymers, but I am not sure how much longer that Xenon board is gong to last if it still works…
                        • 32069
                        Originally posted by Agent24
                        That's why you should check leakage on NOS electrolytics~
                        with a hammer.
                        NOS is not a word that should be used when talking about liquid filled devices.
                        not caps, not batteries.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5401
                          • New Zealand
                          I don't know about those specific Rubycons but I've used plenty of older capacitors that worked fine. If leakage, ESR and capacity test okay, and they aren't physically leaking or smell bad, then I'm happy to use them for the most part.
                          I've seen much younger capacitors fail because they were cheap junk, though.
                          -David VanHorn
                            • 32069
                            the super low esr caps are far more touchy than average ones,
                            even look at an old one the wrong way and they explode all over the place.
                            • joetristan
                              Tantalum capacitor burning out
                              by joetristan
                              I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
                              At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
                              I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
                              I do not understand why the tantalum capacitor burns up?
                              02-11-2026, 03:43 AM
                            • madscientist750
                              Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
                              by madscientist750
                              I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
                              07-09-2024, 09:24 AM
                            • jkucukov
                              ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
                              by jkucukov
                              I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
                              I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
                              How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
                              Thanks,...
                              08-11-2026, 09:00 AM
                            • Prolog
                              by Prolog
                              12-01-2024, 08:27 PM
                            • woodboy971
                              Need help – Identifying missing capacitor (HP CM 6050A2892401 MB A01)
                              by woodboy971
                              I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
                              Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
                              After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
                              My issue is that I cannot identify...
                              12-27-2025, 10:31 PM
