Adding MLCC to replacement cans
  • snme
    • Feb 2016
    • 29
    • AU
    I have circumstances of wet cans failing, especially on ancient motherboards.
    I have a notion to habitually add a 1uf MLCC onto all such replacements.
    is that deemed a useful move?
    Mostly where possible i am replacing by solid caps rather than wet cans.
    • 32069
    pointless on motherboards, they already have lots of ceramics.
    just fit polymers and it will be probably 300% better than original
    • EmperorSunLao
      Help Identifying Replacement Capacitors
      by EmperorSunLao
      Hello everyone, nice to meet you. I'm new to this forum, but I'm a long time tech enthusiast with a sizable collection of hardware that mostly ranges from 1990-present. Sadly, that includes more than a few components that were created between 2000 and 2010, which seems to have been a rather dark time for capacitors. I have some motherboards with failed capacitors that I would like to replace, but determining proper replacements is proving difficult and I was hoping someone here might be able to give me a hand.
      I'm not entirely new at this, as I have desoldered and replaced electrolytic...
      10-07-2026, 10:12 AM
    • Gennady90
      Help Needed With BIOS and ME Region Cleaning After SRKM6 PCH Replacement on HP ENVY 34
      by Gennady90
      Hello!
      I need help repairing and rebuilding the BIOS firmware after replacing the southbridge/PCH on an HP ENVY 34 All-in-One PC.
      Device information:
      Model: HP ENVY All-in-One 34-c0154
      Product Number: 319N5AA#ABA
      Motherboard: DA0NZGMBAF0 REV:F
      Board code: NZG
      System Board ID / SSID: 8927
      HP motherboard P/N: M52651-001 / M52651-501 / M52651-601
      SPI Flash: 25Q128, full 16 MB dump
      Current BIOS version: F.16
      The motherboard originally had a faulty Intel H570 PCH with the SRKM6 marking. The original chip was...
      09-02-2026, 01:54 AM
    • Mattis05
      AON6962 CPU VRM MOSFET on Acer Nitro 5 - replacement options and compatibility
      by Mattis05
      I am repairing an Acer Nitro 5 motherboard with a 4-phase CPU VRM that uses AON6962 dual MOSFETs.
      One of the AON6962 devices at PQZ3 failed on the high side. After removing PQZ3, the short on the CPU VRM input rail disappeared, so I am confident that this device was the actual fault.
      I have already ordered another original AON6962 so I can test the board with the same part first. However, I am also looking into possible newer replacements because I am not sure whether this was just a random failure or a recurring weak point.
      I have seen several other Acer...
      08-28-2026, 01:47 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • asso7512
      ASUS RTX 5060 PEX Regulator – Top Marking 6RHUB / 6RGuA – Replacement Needed
      by asso7512
      I'm repairing an ASUS RTX 5060 8GB graphics card and looking for a replacement PEX voltage regulator (PU8).
      The component has been identified from ASUS boardview/BOM information as:
      • Manufacturer: Silergy
      • Part number: SYV795DFD / ASY795DFD (both references found; exact relationship unconfirmed)
      • ASUS part number: 06018-06760000
      • Top markings: 6RHUB / 6RGuA
      • Package: DFN 2×2 mm, 8 pins
      Pinout from the ASUS boardview:
      1 PEX_EN
      11-05-2026, 07:56 PM
