Tektronix TDS 524a restoration/recaping
  • Fobo
    • Feb 2022
    • 31
    • Sweden
    Got a hold of a Tektronix TDS 524a oscilloscope in perfectly good cosmetic condition but noticed that several of the capacitors had started to leak so I started cleaning all the capacitors off the upper board and the lower one, just wondering what capacitors you would recommend? And what else I need to check it looks like no one has been in it and screwed it in befor!
    Do I dare to run the circuit boards in the ultrasonic cleaner?
    I've checked these capacitors, are they ok for this?
    UCD1A330MCL1GS UUA1A330MCL1GS or https://www.digikey.se/en/products/d...MCL1GS/2550488
    Looking for a wiring diagram but have taken pictures of everything but it seems like it's just 33 µF 10v and 10 µF 35v
    I thought I would get it started first then see if I need to replace Input Hybrid Relays and the NVRAM batteris
    Thanks in advance to all knowledgeable people
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    Personally I wouldn't use SMD capacitors again unless the space is very tight, as they're a pain to solder properly. You can get a miniature series of leaded capacitors and solder those instead. Just bend the leads outwards at a right angle (leave a gap between the body and the bend point so you don't rip the lead out), then cut off the excess lead and solder it on.
    I don't know about the ultrasonic cleaner - some things can get damaged - hopefully someone else can answer that...
    You definitely do need to clean off the electrolyte or it will corrode things, though.
    -David VanHorn
      • 32069
      if it's a big industrial type cleaner you dont want to put mechanical stuff in it or crystals- they can crack crystals
      • rex98
        VSS2 Store Cleaner
        by rex98
        VSS2 Store Cleaner
        DISCLAIMER: Badcaps.net and its members do no support unlocking stolen or company-owned devices.
        The Tool given here are for personal use only.
        THE VSS2 Store Cleaner is FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
        You CAN download it, use it. I only ask that you DON'T modify it ,sell it or try to make a profit
        from it, and that you please credit the authors for the time and work they put into it.
        I TAKE NO RESPONSIBILITY...
        04-09-2026, 05:30 AM
      • SluggerB
        Help me fix my robot vacuum cleaner (LONG and meaty)
        by SluggerB
        I am trying to troubleshoot a Eufy L60 that has turned into a absolute ghost in the machine.
        The history on this unit is pretty strange. For 2 years, it worked just fine. It originally started failing to dock, it would successfully position itself, start driving up the ramp but stopping just short of making electrical contact, sitting there indefinitely while the side brush kept spinning endlessly until the battery died. I cleaned the plastic screen and charging contacts, which seemd to fix that issue, but shortly after, it started reporting it was trapped in the middle of a room,...
        08-12-2026, 10:44 AM
      • itsthatidiotagain
        CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
        by itsthatidiotagain
        CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
        There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
        I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
        A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
        06-23-2025, 03:22 AM
      • nethena
        2017 iMac (A1419) has started ramdomly beeping
        by nethena
        I have a 2017 iMac that I have upgraded it to it's maximum specs (i7 CPU, 64G RAM, NVME, SSD drives). It has been fine for several month, but recently has started ramdomly beeping. If I open a terminal window I get a constant stream of L's. I've tried swapping from a 3rd party bluetooth keyboard to a genuine Mac but the issue perists. Has anyone experienced and/or resolved this issue? Is it likely to be a logic board issue?
        08-23-2026, 08:56 PM
      • xnRS
        Project: COMMANDO
        by xnRS
        Little backstory:
        It all started 2 years ago, when I bought this motherboard in very... very sad condition.
        Seller said that it was installed in a PC, which was stored in a Balcony, which was very humid, and motherboard became... well rusty.
        So, even in this condition it was, in fact, working. But it didn't had ethernet, either PCI-E or PCI wasn't working(I forgot what isn't working, as I tested it 2 years ago) and I think it was all the problems it had. I've tried to do something with it back then, but it was pointless, as I didn't had any soldering...
        11-30-2022, 01:07 AM
