Resistor Question, ca Variable?
  • Valvados
    • Nov 2013
    • 10
    • US
    Where would I get a "ca. 50k variable resistor"?
    "you replace this "zero" resistor with a ca. 50k variable resistor. Setting this variable resistor to ca. 40k gives a ca. 10% voltage boost - i.e. instead of 1.3V, you get 1.43V."
    "reduced by ca. 6%"
    Mentioned here
    http://forums.vr-zone.com/the-overcl...sta-l6714.html
    A mod I would like to perform since I have the mobo and water cooling on it that isn't helping with no overclock being run on the CPU.
    I've done a bit of searching no clue what the ca means. I've found certain resistors matching ranges close to what he mentions but I was wondering if anyone knows where I can get something exact
    I figured this would be a good place to ask since a lot of people here know about soldering and wiring.
    It's also pretty old school like a lot of bad caps products.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Resistor Question, ca Variable?
    Why dont you ask on the Forum it is mentioned on????
    ca. is probably an abbreviation for Circa = approximately
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • waigy
      Variable resistor potentiometer has different reading when mounted on the board
      by waigy
      In my fusion FE-402 car amplifier the gain pot is an RK097G.
      I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
      The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
      I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
      I then took the pot out the board and it now measured 22k.
      I tried putting it back in the board and it goes back to 10k.
      Is this normal and if so what pot should I order?
      On this...
      11-12-2024, 04:44 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
