Problem, Bad caps as culprit?
  • Amaranthus
    • Jul 2007
    After much research i came across this site. Lots of great info here.
    It all started when i moved my pc..like i've done many times before...plugged it back in, turned it on, the fans booted up to the high rpm (which it usually does for about 5 seconds, but then nothing loaded....no BIOS or anything.
    The moniter+mouse didnt connect/register...it just sat there with all case/cpu/psu/gfx fans running at a slightly higher than idle rpm.
    So i took out components to narrow the problem down, nothing. I ended up swaping PSU...still nothing...swapped a new GFX, still nothing.
    Then i put together all the original parts...turned it on and it booted (although wait time inbetween BIOS load+windows splash screen load was extra long + it asked me to activate windows...weird)...
    So...i thought well, maybe ive got it. But i then turned off, unplugged, put in a pci slot card, turned back on and the problem occured again.
    Finally, i unplugged all connections from the PSU to the MOBO...plugged them back in...and turned on..and it worked.
    Now: Whenvere i unplug the computer (psu to outlet) i need to disconnect all connections from PSU to Mobo...then reconnect them....then connnect power to outlet before i can reboot...or the original problem will occur.
    Im really lost here. I havnt seen any bad physical signs of bad caps...but ive looked over the symptoms page's and it seems like it may very well be a possibilty of bad caps on the mobo and/or psu.
    Any info would be greatly appreciated. Thanks.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Problem, Bad caps as culprit?
    Most probably bad caps in the PSU - start with those on the +5Vsb rail.
    • Newbie2
      • Sep 2005
      • 885
      Looks like he already tried the PSU.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • shadow
        • Feb 2007
        • 732
        That is a very strange problem. If you do suspect the motherboard capacitors, then tell us the brands and the series if possible of the capacitors. If they are known bad capacitors, then the forum members can confirm if it is likely that they are bad or not.
        • Amaranthus
          • Jul 2007
          Thanks for the replies.
          To update: I noticed that if i bumped the tower a certain way the comp would freeze...i went through lighting figiting with components(carfully and only touching parts i know could be touched while it was powered on) and concluded the gfx card (pci-e) waas a little loose and causeing it to freeze. After i found that out and rebooted a few times. The process before: disconnecting all conections from psu to mobo, would no longer work to boot up.
          So im back to square one kinda. But ive changed GFX cards too...and played with the fitting in the slot and im having the original problem.
          What i will do now: Check the model/manufaterers/type of caps on the mobo, then post them here.
          Going to bring the comp to the guy who helped me build it and let him spend a few days on it.
          Thanks for the help. Whatever the problem may be i will post it here when we figure it out, if its not bad caps, at least it might be helpful to someone at somepoint.
          • bulkchart32
            i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
            by bulkchart32
            i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
            06-16-2025, 03:09 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • looxuser
            why is my problem fixed when I ground caps?
            by looxuser
            I have an audio device with two caps around an ic amp JRC2073. I replaced these two caps and the no audio fault remained, however by chance i shorted the exposed caps of these two with a finger each on one hand and got audio. My hand resistance was about 0.4mohn so i tried large resistor across instead and got audio too, why is this please? All the solder joints look and test good.
            06-04-2023, 03:36 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
