Fried capacitor on Dell-5520. Guilty as charged.
  • Lapsmith
    • Jul 2025
    • 12
    • USa
    While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy back to PC4427:
    Click image for larger version  Name:	Schematic 1 zoomed.jpg Views:	0 Size:	59.0 KB ID:	3676587
    Here is the location of PC4428
    Click image for larger version  Name:	Boardview PC4428.jpg Views:	0 Size:	10.0 KB ID:	3676588
    And here is PC4427
    Click image for larger version  Name:	Boardview PC4427.jpg Views:	0 Size:	9.1 KB ID:	3676589
    My other question, just for my own education, is why are these two caps necessary, since there appear to be a bank of 12 of them (on the schematic, at least?
    Click image for larger version  Name:	Schematic 2.jpg Views:	0 Size:	75.6 KB ID:	3676591
    Here is the damage and I will remove the remains of the old cap to make sure it doesn't short
    Click image for larger version  Name:	20250706_224132_resized.jpg Views:	0 Size:	139.2 KB ID:	3676592
    • 31301
    what the schematic doesnt show is the distribution of the caps,
    they are connected between different i.c.'s to stop noise from one effecting others.
    • Lapsmith
      • Jul 2025
      • 12
      • USa
      Copy that, thanks.
      Regarding stacking the two smd capacitors, would heat dissipation be an issue? Do they even get warm? I'm thinking not since they don't have a power rating. Any other reasons not to do it?
        • 31301
        it shouldnt be an issue, clean the damaged area first and see if you can recover a connection-point
        • tbsmith
          • Sep 2016
          • 22
          Thanks, will do. I'll remove the mobo to make sure no damage on the other side and hopefully get a good connection point on the top side.
          • tbsmith
            • Sep 2016
            • 22
            Just to close out this thread, I removed the remnants of the old capacitor and the traces on the ground side were gone. So I mounted the replacement cap directly on top of the other one (PC4427) and it is working fine. Thanks for all the help! Will be donating to this awesome site.
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • Nier
              Drilling out solder from capacitor holes
              by Nier
              I have an xbox 360 board that had 4 leaked electrolytic capacitors. I desoldered all 8-10 capacitors (1500uf 16v) since 4 leaked and wanted to replace all of them. 2 capacitor legs broke and were stuck in the through hole.
              My two solder suckers just didn't work and I decided to use my dremel lite in the lowest speed to drill out the broken capacitor legs. I used a carbon drill with the exact diameter size as the capacitor hole. I drilled out the capacitor legs but I think that I damaged the holes. I don't think that the solder will adhere through the hole if If I solder a new capacitor....
              10-05-2021, 09:48 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • Agent24
              Dick Smith Q-1760 linear power supply filter capacitor question
              by Agent24
              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
              It has at least one problem.
              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
              I have already ordered a replacement potentiometer, so that's not an issue.
              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
              All are CapXon...
              10-21-2025, 05:39 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
